27th September 2013, 08:36 AM
changing gears to quick
My patrol is changing gears going up hill way to quick , i can hold it in a gaer but wondering if any ideas out there ti4500 petrol 98.
27th September 2013 08:36 AM
27th September 2013, 10:55 AM
Patrol Guru
G'day Bubsy.
You running an automatic presumably? Sounds like the kickdown sensor/switch could be mucking up.
Does it do it under normal driving conditions (no load flat surface) or is it just under load (towing trailer, boat, caravan)?
Cheers,
Rob
Just about to jump into my next Patrol. A 2001 GU II TB45E .
WARNING!: Do not ever use a towball as a recovery point. They are not rated and can become a deadly projectile during a recovery if they snap off, and they have done so with tragic results in the past.
27th September 2013, 10:58 AM
I would check your TPS. It may be faulty or have dirty terminals etc.
Hello from Under Down Under!
