23rd September 2013, 06:41 PM
Gq Speedo adjustment to read correct speed
I just adjusted my speedo on the GQ dash. I was sick of it reading 8km low at 100km.
Instructions.
Pull the cluster out -
You need to drill a hole in the TOP WHITE part of the cluster assembly.
1. Take a straight line to the top of the speedo cluster from the 90 Km mark on the speedo. Continue the line towards the circuit board at the back of the speedo.
2. 15 mm from the rear circuit board drill a 5 mm hole - in the white housing where the line above intersects.
3. If you have the hole in the right spot you will see a variable resistor when you look though the hole - there is only one on the speedo circuit board.
Re-assemble the cluster and install back into the GQ - leave the screws out.
To adjust -
Lean the cluster forward, use a long small blade driver and a tourch to see. Turn the trim pot - (does not need a lot of movement). male an adjustment and go for a drive.
Calibrate against a GPS - I had my son reading out the GPS speed while I watched the speedo.
I found that when I was holding the cluster with the display towards me
Anti-clock wise increased the displayed speed.
Clock wise decreased the displayed speed
The speedo is now reading 100km at 100km
The Following 6 Users Say Thank You to GQ TANK For This Useful Post:
AB (23rd September 2013), jayisbikes (11th October 2014), menace 2 (26th October 2014), NissanGQ4.2 (12th October 2014), Rossco (15th April 2022), Sherro (26th December 2014)
23rd September 2013 06:41 PM
11th October 2014, 10:07 PM
thanks GQ TANK, I just fitted 285/75R16s so I'll give it a shot tomorrow :-)
26th October 2014, 09:21 AM
Adjusted it yesterday. My potentiometer was located in line with the 95km/hr mark on the speedo. Easily found it by popping the front clear housing off the front of the instrument cluster. Thanks again :-)
1st December 2014, 03:19 PM
GQ TANK
Instructions.
To adjust -
Does anybody know if this is possible on a GUll?
26th December 2014, 08:27 AM
Does anyone have some pictures? it would be much easier then....
22nd February 2015, 01:02 PM
Don't think it will be possible on the GU, they use a microcontroller (computer chip) to read the speed and move the dial. The GQ used all analogue circuits, that is why it has the potentiometer.
22nd February 2015, 01:05 PM
I am he, fear me
Just change the VSS drive cog in the gearbox to the correct number of teeth.
Easier, simpler, quicker but you are up for the cost of the dinky little gear.
22nd February 2015, 05:05 PM
Mine is 5KM out since putting 33" on, so this is of interest to me. Thanks.
Grzesiek3M
Yeah pictures would really help us novice types out.
Owner of 1984 SD33T MK Patrol
Owner of 1989 TD42 GQ Patrol
Previous Owner of a 1988 TB42 DA Maverick
15th April 2022, 10:23 AM
Thanks GQ Tank
Spot on. My cluster has already a hole in the right spot. Now to fiddle. Cheers Tractor
