21st September 2013, 09:46 PM
Leaking Rocker Cover
Can any one tell me if i should use a sealer on my rocker cover gasket,its a rd28t,i have just replaced the head and ran the engine and the rocker cover is leaking,i have tighten it down but it still has a slight leak, i don't want to tighten it to much in fear i might break the bolts in the head,its also a new gasket.
21st September 2013 09:46 PM
21st September 2013, 11:31 PM
when I do put new gaskets on, I use "stag paste" smear it over the gasket and the the other side,,it seems to work pretty good
22nd September 2013, 06:30 AM
Ok i will give that a go,thanks for the reply mate,i have never heard of stag paste.
23rd September 2013, 03:07 PM
Patrol Freak
Mine also leaking.
I tried change gasket, then used liquid seal with gasket, doesn't work.
I think mine rocker cover is curved.
May be you have the same problem.
I'm Alexander and I'm the happiest owner of GQ Nissan Safari in the whole Central Asia
29th September 2013, 09:03 AM
Couldn't get any stag paste so i just used permatex worked perfect no more leaks
29th September 2013, 10:15 AM
Legendary
i think stag paste has been taken off the market as it has one of those bad chemicals in it
the only reason i know this as a plumber i used it alot
and the plumbing supplier told me this
2007 GU 6 /ST-L / MYO8 / DIESEL/AUTO /MOONSTONE /pro vent 200
OH LEATHER IS NICE
The Following User Says Thank You to my third 256 For This Useful Post:
