20th September 2013, 09:02 PM
Just bough a 2000 Patrol. creaking sound on take off
Hi,
Three issues on my "new" Patrol
when I drive off the car creaks, sounds like a suspension issue but where to start looking?
also there is a definite clunk sometimes as if the drive train is taking up slack?
l any help is appreciated!
cheers
20th September 2013 09:02 PM
20th September 2013, 09:16 PM
Patrol Freak
I'm no expert but I'd be checking the universal joints first
20th September 2013, 09:20 PM
Smart like tractor
I would start looking at the suspension....all of it every nut, bolt and bush
96 GQ coil/Cab
08 G6eT
20th September 2013, 09:27 PM
Administrator
Does the clunk only happen when taking off? Only when putting the foot down moderately hard not just a slow take off?
Check your drive shaft as well if the bolts may be loose at the front journal plate area. This happened to an old car I had with a clunk when you took off and was only loose bolts
Could be a million reasons why though. Process of elimination!
Any more info?
Patrol Freak
Broken engine mounts/gearbox mounts can give the impression of too much driveline slack. Hard to check unless you completely remove them. Generally the passenger side engine mount is the first to go. How many km on the car? You might be able to check with a torch and mirror for splits, but it isn't always obvious. Loading up the engine gently in the driveway and having someone watch the engine might give you an indication of too much movement.
20th September 2013, 10:01 PM
car has 200K km. as Nissans are new to me I thought it might be a known issue
20th September 2013, 10:22 PM
Legendary
Radius arm bushes, body mounts, engine mounts, uni joints.......all detective work mate.
1999 GU 4500 dual fuel
Il dado è tratto
20th September 2013, 10:50 PM
yep just looking for a starting point!
20th September 2013, 11:04 PM
Dribble Master
Seriously mate, it really will be a process of elimination. Clunks, creeks, squeaks, moans and groans could be any number of things and it's not always easy to give a correct answer going off someone's description. Me personally, I'd get underneath, start at the front, or the rear if you prefer and systematically check everything.
21st September 2013, 07:42 AM
ok then thats the weekend plan, cheers
