Page 1 of 2 12 LastLast
Results 1 to 10 of 11
Thread: Voltage boost fuses
    Voltage boost fuses
    Hi has anyone used these fuses that are supposed to increase the charge rate of your Alternator.
    SUCH IS LIFE Maxhead's Avatar
    ACT
    I haven't used one but check this thread out from last year http://www.nissanpatrol.com.au/forum...oltage-Booster
    ________________________
    ______ 2017 D-Max _______
  4. The Following User Says Thank You to Maxhead For This Useful Post:
    threedogs (18th September 2013)
  5. #3
    Only read down to Yendor and after he said no that's good enough for me.
  6. #4
    Legendary NP99's Avatar
    Feb 2013
    Broadford VIC
    Just like fuel saving devices.......
    1999 GU 4500 dual fuel
    Il dado è tratto
  7. #5
    Thanks , $50 for a modified fuse seemed a bit steep
  8. #6
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    On some vehicles, like the newer LandCruisers, the ECU reduces the alternator output to help reduce fuel consumption.
    This can cause problems when a second battery if fitted. From what I have heard fitting a voltage boost fuse helps overcome this.
    TD, yes it is very expensive. It's only a diode placed inline with the fuse.
  9. The Following User Says Thank You to Yendor For This Useful Post:
  10. #7
    A mate of mine was told that in his new Hilux he would need a DC-DC charger to make dual batteries work, he had a regular dual battery isolator lying around so he tried it and has never looked back.
  11. #8
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    That's the downside to the interweb thingy
    You get some people that will read something somewhere and then repost it with such conviction you think the information must be correct.
  12. #9
    Yeah he was told that by ARB though, maybe they read it on the internet! bahahah
  13. #10
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    I wouldn't think so........more likely trying to improve their bottom line (allegedly)
