16th September 2013, 06:24 PM
Can I fit 31” tires without any lift works?
Hi everyone!
So, what do you think can I fit 31” tires, without any lift works on my Y60 94?
I think to use R15 discs from Pajero.
I'm Alexander and I'm the happiest owner of GQ Nissan Safari in the whole Central Asia
16th September 2013 06:24 PM
16th September 2013, 06:25 PM
The 747
Yep the 31s will fit without a drama mate! They are standard issue on the Patrol mate.
The Following User Says Thank You to Winnie For This Useful Post:
Wine_maker (16th September 2013)
16th September 2013, 08:34 PM
Dribble Master
31" tyres are not a problem at all mate. If you're wanting to use the rims off a Pajero, I doubt if they will seat properly on the patrol hubs. The Pajero stud pattern is 6x 139.7mm with a 108mm centre bore and the Patrol stud pattern is 6x 139.7mm with a 110mm centre bore.
Someone who has a better idea might be able to help you further.
The Following User Says Thank You to Clunk For This Useful Post:
Wine_maker (17th September 2013)
16th September 2013, 09:09 PM
i was running 33in on mine without a lift for years no problem just a little bit of rubbing every now and then
The Following User Says Thank You to 93patrol For This Useful Post:
