Results 1 to 4 of 4
Thread: Can I fit 31” tires without any lift works?
    Patrol Freak Wine_maker's Avatar
    Nov 2011
    Kazakhstan, Almaty.
    8 Post(s)
    Hi everyone!
    So, what do you think can I fit 31” tires, without any lift works on my Y60 94?
    I think to use R15 discs from Pajero.
    I'm Alexander and I'm the happiest owner of GQ Nissan Safari in the whole Central Asia
    201 Post(s)
    Yep the 31s will fit without a drama mate! They are standard issue on the Patrol mate.
    Wine_maker (16th September 2013)
    31" tyres are not a problem at all mate. If you're wanting to use the rims off a Pajero, I doubt if they will seat properly on the patrol hubs. The Pajero stud pattern is 6x 139.7mm with a 108mm centre bore and the Patrol stud pattern is 6x 139.7mm with a 110mm centre bore.
    Someone who has a better idea might be able to help you further.
  6. The Following User Says Thank You to Clunk For This Useful Post:
    Wine_maker (17th September 2013)
  7. #4
    Legendary 93patrol's Avatar
    Dec 2012
    Bunbury
    i was running 33in on mine without a lift for years no problem just a little bit of rubbing every now and then
  8. The Following User Says Thank You to 93patrol For This Useful Post:
