Page 1 of 2 12 LastLast
Results 1 to 10 of 12
Thread: Safely Using a Snatchem Strap
    581 Post(s)
    Correctly pulling someone out using a snatchem.
    Advanced
    Apr 2011
    I was shown many years ago to saddle the strap with a wet hessian bag to dampen the strap incase it comes away from its anchor.
    Thanks for the video
    TOOR
    Legendary
    The wet hessian bag would make a good damper but places like ARB, TJM and Opposite Lock sell proper damper blankets that won't make the inside of your car wet when you put them away.
    Tony
    Patrol God nowoolies's Avatar
    Perth
    sorry but that aint the safe way
    NO damper on the snatch strap
    time to redo the video
    HELL NO !!!!!!
  6. #5
    Gert B Frobe
    Guest
    Ive never seen dampers used when snatching but always with winches. Whats the general rule? Or is it just best to go for overkill on the safety side of things?
  7. #6
    W.A. (wandering aust)
    Quote Originally Posted by Gert B Frobe View Post
    Thats because a damper in the middle of a snatch strap does very little in 95% or more of cases if something lets go other than a strap eye.
    The damper on a winch cable is to defuse the danger of the cable itself causing damage. Snatch strap fatalities etc are from getting hit by the lump of metal that is/was attached to the strap. In the most recent fatality it was part of a bull bar. A damper would have done nothing in that tragedy
    With a strap it is the flying object (lets say a shackle) that kills not the strap. A strap has transfered 100% of the stored kinetic energy to the shackle in the first 20% of contraction... the damper will probably not have even hit the ground by then.
    If the shackle 'flys' then the damper is irrelevant
    If the shackle remains attached to the strap and the strap is in one piece it can only hit something within 120% of the length of the strap which is 99.9 times the vehicle attached at the other end
    If the strap breaks then you have no flying object other than the longest part of the 'soft' nylon strap which is about the only time the Damper will come into play
    IMHO when using dampers on a strap you need 2, one at each end not 1 in the middle but by far the safest option is the latest generation of straps with anti recoil webbing.
    Bottom line tho always remains "if you aren't happy with a method either change it till you are or do not do it that way at all."
  8. #7
    There is NO way to safely snatch somebody out. Sure there are ways to make it a little safer, but it's always a dangerous exercise.
  9. #8
    RIP - valued member and true gentleman of this forum that will be missed by many! Silver's Avatar
    Feb 2011
    Brisvegas
    Quote Originally Posted by KRISTOFFA View Post
    That's probably true Kristoffa, in the sense that all activities carry risk, but if everthing is kept well within the safety limits then snatching should be, and in my experience has been, uneventful and effective.
    Where things go wrong is where people push the limits with big run offs and high speeds, or dodgy attachment points. On top of that are recoveries where the vehicle is already teetering on the brink of disaster
    "As a boat owner and a four wheel drive owner I feel like a pelican: every where I look I see a big bill in front of me”
  10. #9
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    Quote Originally Posted by nowoolies View Post
    yep i have to agree
    Hello from Under Down Under!
  11. #10
    Hardcore the ferret's Avatar
    Sep 2010
    on the coast W.A.
    At the request of another member, I have put this up again just as a reminder,
    have a good look at it and think about what you're doing next recovery.
    Cheers, the ferret.
  12. The Following 2 Users Say Thank You to the ferret For This Useful Post:
    Sir Roofy (28th December 2011), taslucas (28th December 2011)
