11th September 2013, 02:15 PM
BIG & BALD
Auto windows modification.
Does any body know if you can make the passenger side window into auto down/up like the driver side on the GU's.
Can I just buy an auto button in the spot of the passenger window button or is it the motor that does the auto bit.
It's been something that has been bothering me for a while but I have a feeling it can't be done. Not cheaply anyway.
11th September 2013 02:15 PM
11th September 2013, 04:42 PM
I think it's a little more detailed than just the switch. You need some sorta end switch, I think the work like an over load switch on the drivers side..
But I'm not sure where that circuit is.
In the q they have a black box inside the door which holds a lot of electronics. Im pretty sure Its the controller for the other Windows but possible has the limit switch to..
Nit sure what would happen if you bolted one into the passenger side setup with the 2 stage switch..
MEGOMONSTER (11th September 2013)
11th September 2013, 05:01 PM
The GUs have a limit switch in the driver door regulator and circuitry in the drivers master window switch that controls the auto function for the drivers electric window.
I think it would be very difficult to set up the auto function on the passengers window.
11th September 2013, 05:35 PM
BIG & BALD
Yendor
Of course it would, why would Nissan make it easy.
Did they make a left hand drive version of the GU/GR ?????
BigRAWesty (11th September 2013)
11th September 2013, 05:39 PM
BIG & BALD
threedogs
Already sounds expensive.
11th September 2013, 06:03 PM
threedogs
They would have, but electrical would just be swapped..
11th September 2013, 06:18 PM
BIG & BALD
Westy's Accessories
So I need to find a cheap complete drivers door and change the internals.
11th September 2013, 09:31 PM
MEGOMONSTER
I'm not sure how the system would run with 2 controllers?? You could try.. Have and Extinguisher at the ready but..
12th September 2013, 08:28 AM
@ Kallen if LHD wouldn't it be handed as in mirror of RHD.
Or do you think they just swap the lot and only change armrest buttons
Nah,,, has to be left handed to fit...cause its a left handed door.
My thinking is if you take RH unit out it won't fit on LH side it needs to be Mirror image to work.
Sort of like the RH mirror won't fit on LH side
