Results 1 to 7 of 7
Thread: Is this a safe recovery point?
    Advanced thebrod's Avatar
    Sep 2013
    Hi all
    Only recently purchased my Patrol, and have seen a lot of discussion about suitable recovery points. My car doesnt seem to have the hook that is talked about alot here but has what I have attached in the pics. Are these suitable as a recovery point? they look fairly sturdy to me, and there is on on each side at the front, but the last thing I want is for something to come flying off!!
    Adam
    If it is painted red It may be one of mine.
    my tow points are proof rated to 3.5 ton
    and like any bit of recovery gear if it looks suss throw it out and get another one.
    It may also be a copy but I cant vouch for them only mine
    Expert gec's Avatar
    Geraldton WA
    Yeah mate, that is an after market recovery point and is safe to use responsibly, as long as the bolts are the high shear or high tensile strength and not just normal mild steel bolts. I'm pretty sure they should have lines or number's on the head of the bolt that will let you know what they are, and if I'm wrong about the bolts I'm sure there is someone on here that will let you know,
    Cheers.
    Western Patrol Club member
    GQ with 5.7 Gen 111 V8, Dual ARB airlockers, 33" Coopers, 9000lb Premier winch, Black Widow draws
  5. The Following User Says Thank You to gec For This Useful Post:
    growler2058 (25th April 2014)
    Feb 2011
    Shed
    45 Post(s)
    Quote Originally Posted by gec View Post
    Cheers.
    X2...............
    Sep 2013
    Cool. Thanks guys
    462 Post(s)
    Five lines on the head of the bolt is grade 8 hi tensile steel...
  9. #7
    Advanced bindi's Avatar
    Apr 2014
    Gippsland
    thanks also from me too, I might see if I can't make some
