Results 1 to 8 of 8
Thread: change to 4.3 diffs worth the work
    Patrol Guru matfew's Avatar
    Nov 2012
    Hey guys n gals
    I have some 4.3 diffs from a rb30 patrol sitting here. I am weighing up selling them or using them.
    I got a TD42 gq with 4.1's ofcourse atm. Will be running 35's soon along with turbo. I know the 4.3's bring the speedo back about right with 35's but with the turbo will I need to go up in diff ratio?
    Any opinions would be great
    brisbane
    I don't know much about the ratios you will require but if that's the correct one I'd be putting it in so it won't be so sluggish and fuel consumption will be lower also.
    43 Post(s)
    A 4.1 to 4.3 will keep Speedo right for 33" tyres..
    If you have em, yes.. It'll bring the ratios back and give you a better torque rating at the wheels..
    If your going 35`s then 4.6 ratios will keep everything Stock, but 4.3's are better than nothing..
    Nov 2012
    thanks. I'm just curious if with the turbo and extra torque will i need to worry about moving to 4.3's or 4.6's.
    Its got 33's on it now with the 4.1 and have had 35's on it before. It was a bit slower but these things ain't race cars lol
    Expert pbk1776's Avatar
    I think 4.3 will be better for your 35"
    I used to have this chart showing ratios and the rpm per tyre size
    If I find it I will post it here
    330 Post(s)
    just confirm that you have 4.1s now. i assume you have a NA GQ TD42 in which case you will likely have 4.1s my GUIV TD42Ti runs 3.9s and i have 285s with no trouble at all. i have run it with 35s and it does that easy to. My GQ is a TD42T and i have 4.6s in that. Nice and torquey. If you have them there will be a benefit but t wont be huge. You could hold off until your ready for the turbo or for lockers the fit the lockers to your 4.3s and then swap out the 3rd members.
  8. #7
    Here is the chart im talking about - might assist you with your questions
  9. The Following User Says Thank You to pbk1776 For This Useful Post:
    Parksy (11th September 2013)
  10. #8
    Nov 2012
    Yeah 4.1 now. I was the only na diesel at the high country trip recently. silver gq.
    Anyway I have a buyer for the 4.3 so just trying to decide if I should keep them Or sell them.
