Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 43
Thread: tractive effort to Newton Meter
  1. #21
    22 Post(s)
    Quote Originally Posted by Drewboyaus View Post
    Where did 2300 come from?
    I've just gone and compared it to the one from that Nissan forum and he's getting 6300 for his TE figure and I reckon that's more like what you should be seeing based on how much power you're making.
    Tip tip tip......tap tap tap....
    1700 ft lb ( as per dyno sheet) = 2300N
    96 GQ coil/Cab
    08 G6eT
    Hardcore
    Coffs Harbour
    You have about 660-670nm now. Before hand you maybe had 500
    G'day Killer-Wasp,
    You have to always bring sex into some of your posts! (660-670nm) lol
    Regards,
    RLI
    The halls been rented the bands been paid, time to see you dance!
  4. #23
    Hardcore
    Coffs Harbour
    Newton Meters is at the flywheel and Newton tractive effort is torque at the wheels as torque is multiplied by gearing
    Fark, your another one,Ben-e-boy, has to bring sex into the equation. lol
    Regards,
    RLI
  5. #24
    North brissy
    Right, so the equation is
    TE= (T × R × 1000)/r
    TE=2300
    T= ?
    R=4.11
    r=412.5
    Have a crack and see what you get
    There is more too it than that. It's not as simple as that equation would make it seem. Just do what I did and ask someone smarter lol
  6. #25
    CERTIFIABLY INSANE Drewboyaus's Avatar
    Oct 2011
    Essendon
    A bit more reading and the equation asks for the Torque figure in Kg/mm. How does that affect the final figure?
    1997 GQ Patrol RX, TB42E. Mods: OME 2" lift, 33" BFG KM2'S, ARB winch bar & reconditioned X9 Superwinch, IPF 900 spotties HID conversion, ARB side steps and scrub bars, Kaymar rear step & spare wheel carrier & jerry holder, Rear 55W LED worklight, Safari Snorkel, 147L LRA tank, Extended diff breathers, dual batteries, GME UHF, Home built drawer and fridge slide, ARB 60L fridge.
  7. #26
    Sep 2012
    Mount Gambier, SA
    43 Post(s)
    I was thinking the same.. Your diff ratio is 4.11 but that wouldn't be the figure your after..
    You would need to also add in the gear box ratio, sure they try get 1:1, but I think it's a little Off from that..
    22 Post(s)
    What does that person have,
    96 GQ coil/Cab
    08 G6eT
  9. #28
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    smarterness
    Hello from Under Down Under!
  10. #29
    22 Post(s)
    Lots, I just used a converter to Nm and its 2.25 lol
    96 GQ coil/Cab
    08 G6eT
  11. #30
    Oct 2011
    Essendon
    Hahahha......might have to start a new thread "the 2 and a half killer wasps" hahahahh.
    It would be interesting to see if there is another version of the equation to be found on the Internet.....
