9th September 2013, 06:55 PM
#11
The 747
Have you had it tuned Benny?
9th September 2013 06:55 PM
9th September 2013, 07:00 PM
#12
Can someone explain the difference between the two in layman's terms?
Hello from Under Down Under!
9th September 2013, 07:19 PM
#13
Smart like tractor
Winnie
Yep the dyno sheet is in the killer wasp thread.
96 GQ coil/Cab
08 G6eT
The Following User Says Thank You to Ben-e-boy For This Useful Post:
9th September 2013, 07:21 PM
#14
Smart like tractor
taslucas
Newton Meters is at the flywheel and Newton tractive effort is torque at the wheels as torque is multiplied by gearing
96 GQ coil/Cab
08 G6eT
The Following 2 Users Say Thank You to Ben-e-boy For This Useful Post:
PMC (9th September 2013), taslucas (9th September 2013)
9th September 2013, 07:27 PM
#15
Ben-e-boy
Ahhhh, cheers, so it's pretty straight forward. Just like kw and rwkw?
How would one ever measure in newton metres? That would only really be factory specs unless you pull your donk out and put it on engine dyno?
So all dyno figures are in Newton tractive effort torque.
9th September 2013, 07:28 PM
#16
Smart like tractor
Right, so the equation is
TE= (T × R × 1000)/r
TE=2300
T= ?
R=4.11
r=412.5
Have a crack and see what you get
96 GQ coil/Cab
08 G6eT
9th September 2013, 07:33 PM
#17
Smart like tractor
taslucas
Year pretty much, I think some dyno programs can work out Nm
96 GQ coil/Cab
08 G6eT
9th September 2013, 08:38 PM
#18
CERTIFIABLY INSANE
Ok, so I get 230. That still seems a bit light on.
Looking at the equation, 2300 seems a bit low if that is the TE number. Based on your ratio (known) and wheel diameter (known) and there is a constant (x1000) the key number is that TE value of 2300.
Tip tip tip......tap tap tap....
1997 GQ Patrol RX, TB42E. Mods: OME 2" lift, 33" BFG KM2'S, ARB winch bar & reconditioned X9 Superwinch, IPF 900 spotties HID conversion, ARB side steps and scrub bars, Kaymar rear step & spare wheel carrier & jerry holder, Rear 55W LED worklight, Safari Snorkel, 147L LRA tank, Extended diff breathers, dual batteries, GME UHF, Home built drawer and fridge slide, ARB 60L fridge.
9th September 2013, 08:49 PM
#19
Smart like tractor
Thats what I have been getting, less than a factory NA
96 GQ coil/Cab
08 G6eT
9th September 2013, 08:53 PM
#20
CERTIFIABLY INSANE
Where did 2300 come from?
I've just gone and compared it to the one from that Nissan forum and he's getting 6300 for his TE figure and I reckon that's more like what you should be seeing based on how much power you're making.
