8th September 2013, 06:35 PM
Rear barn door rattles
Hi all
I've been trying to track down an annoying rattle in the back of the patrol and it seems it might be the large rear barn door. If I hold the spare wheel and try and pick it up, it appears to replicate the sound.
Anyone had a similar issue and found a solution? Does it sound like a hinge replacement might solve it?
Thanks for reading
Andy
8th September 2013 06:35 PM
8th September 2013, 06:39 PM
If the hinge prices are anything like Toyotas I'd be more inclined to drill and fit larger pins if that's where your problem is
Tojo want $390 each
Parksy (8th September 2013)
8th September 2013, 06:57 PM
Wow that's scary. I think I will have to investigate further to be sure. I was just curious if anyone had a similar drama as I'm sure I wouldn't be the only one.
8th September 2013, 07:05 PM
Didn't someone slide a piece of plastic tubing over the loop part to stop the rattle , MR did it too I think
8th September 2013, 07:37 PM
Nice. If someone who has done this can explain what they did or post a photo that would help a lot.
8th September 2013, 07:45 PM
Check the archives wasn't too long ago,
8th September 2013, 07:48 PM
Mine rattles sometimes, and it isn't that old ...... it is a Nissan thing with the weight of the spare tyre on the back door....
Mic
The Following User Says Thank You to happygu For This Useful Post:
8th September 2013, 07:50 PM
It is the top latch normally and as a quick fix to stop me going insane and killing the innocent I stuck electrical tape around it and problem solved for now...
Where the large doors latches to at the top should be the culprit.
The Following 2 Users Say Thank You to Bloodyaussie For This Useful Post:
Parksy (8th September 2013), threedogs (8th September 2013)
8th September 2013, 07:56 PM
Thanks BA! Much appreciated, will give it a go.
8th September 2013, 09:24 PM
Gday, recently had same prob n flashing on/off int light coz of door. Used impact driver to untension U plates, tapped em inwards with hammer, slam doors, retension.
Problem solved, can even notice bit tighter opening handles, nice 5 min job.
Do top n bottom of doors .
Daz
The Following 4 Users Say Thank You to Bluecrab For This Useful Post:
cgm (9th September 2013), Kast (2nd February 2014), Parksy (8th September 2013), threedogs (5th February 2014)
