8th September 2013, 04:10 PM
Advanced
Autron gauges - postive & negative dash light wires??
Hi all,
I mite be missing the obvious here? where's the best place to hook up the 2 wires for the positive & negative dash lights used to run the lights for the gauges?? I've sorted the ignition an got power but I've stumped myself here!!
2012 GU8 ST manual.. Not so stock standard anymore
8th September 2013 04:10 PM
8th September 2013, 05:03 PM
How's the serenity
Wired mine up all from the dimmer switch so you can still adjust the brightness of light for the gauges .
The Following User Says Thank You to boots For This Useful Post:
threedogs (8th September 2013)
8th September 2013, 10:43 PM
Advanced
Ha that's what I ended up doing after having a chill an thinking about the situation..
Sent from my AMID-9743G using Tapatalk 2
9th September 2013, 06:01 AM
BIG & BALD
Yep, mine is also wired into the Dimmer switch.
But my gauges start to flicker when I dimmer is really low.
18th September 2013, 11:12 PM
Hey there
IF you have any factory switches in your dash and they light up, you can tap of the light wire there I guess, Use a multimeter or test light to make it a bit easier
