5th September 2013, 09:53 PM
Noise / Rattle at low revs
I have a 2005 4.2 turbo diesel. I get a noise or rattle sound when low revs, is this normal. If so can someone explain to me what the noise is.
If it is not normal can someone tell me what the noise could be and what do I need to fix it.
Truck has 145000 Kms. I have owned since it had 17000 Kms. The noise rattle has always been there
5th September 2013 09:53 PM
6th September 2013, 12:50 AM
Mate throw her back a gear and it will go away, mine does the same and a couple of others do to when you are too low in revs and labouring the engine, some are worse than others.
6th September 2013, 12:53 AM
Yep as strop said, mine rattles from 600-1000 rpm.. Done it since New..
Something to do with the harmonics of the engine and gearbox..
6th September 2013, 05:43 AM
Thanks guys. So it's not a problem as such, it just does it ?
'shakey'
6th September 2013, 07:27 AM
My 2004 4.2 owned since new and does the same, some call it gear box chatter so ive been told.
