Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 41
Thread: My roof console
  1. #21
    Enjoying the trips macca's Avatar
    Oct 2010
    Old Bar, NSW
    13 Post(s)
    For ideas only,,,, some strip Led would fit well on the upper inside edge.
    TD you are on to me as well, have some strips about 400mm long left over from a job that I was thinking of using, you blokes are good LOL
    Macca
    Expert sil3nt_dr3ams's Avatar
    Mar 2013
    mate get some 3 in 1 water based primer from bunnings brush it on. 3 coats should do it let it dry in the sun a few days. sand it back with 240-360 white sand paper then re bog what needs to be done. Prime sand again then lay some coats of color on it. Bit of stuffing around but its worth the effort.
  4. The Following 2 Users Say Thank You to sil3nt_dr3ams For This Useful Post:
    BigRAWesty (21st September 2013), macca (21st September 2013)
  5. #23
    Sep 2012
    Mount Gambier, SA
    43 Post(s)
    Ok I was thinking a grey carpet, but you've sold me on the paint..
    Sep 2012
    Mount Gambier, SA
    43 Post(s)
    Also what points have you used to anchor the console up?
    I know the rails in the wagon roof are like unistrut so a small plate can be slid in and tightened to.
    Some use the light mount, but I would this would be a little weak..
    Oct 2010
    Old Bar, NSW
    13 Post(s)
    Westy I have put rivnuts where the mirror was and the visor clips so 4 5mm bolts in the front. Rivnuts where the light was looks after the rear. Aluminium angle bolts to the roof and hinges or over center latches attach to that Then some small bungees on each side of the shelf at the grab handle front bolts area.
    Macca
  8. The Following User Says Thank You to macca For This Useful Post:
    BigRAWesty (25th September 2013)
  9. #26
    Need an update , Idea #67 what about a textured paint or cover with vinyl
    just need update and more pics, carpet is so 80s lol
    Gotta love those rivnuts, as my BFF from airport says slightly squash and they then become
    lock nuts
  10. #27
    Oct 2010
    Old Bar, NSW
    13 Post(s)
    I have gone with matt black paint and a moulded rubber around the "head but" edges.
    Most of the thing is not seen and as no direct light shines on it, it looks fine with just a coat of paint.
    Get some pics after www tonight maybe, at the wiring stage now
    Macca
  11. The Following User Says Thank You to macca For This Useful Post:
    threedogs (25th September 2013)
  12. #28
    Mar 2013
    waiting for pics, wiring my fridge control panel atm.
  13. #29
    Advanced brwndoggy's Avatar
    Dec 2013
    Redbank Plains
    love ya work macca, any pics on this finished?
  14. #30
    Oct 2010
    Old Bar, NSW
    13 Post(s)
    Quote Originally Posted by brwndoggy View Post
    I have forgotten the pics, actually thought they were already posted. Away in the Sunday car so when I get home.
    Macca
