4th September 2013, 02:30 PM
Should I buy this GQ
G'day guys,
it has been a while since I logged in. I'm slowly getting over the loss of my 4.2l GQ with full touring setup which got stolen a few month ago. And the best way to do that is to buy a new one, right?
After lots of searching in the last weeks I came across this one here:
http://www.carsales.com.au/private/d.../?Cr=8&sdmvc=1
Not the lowest ks and not in mint condition but seems very reasonably priced. From calling the bloke I know that it has a "minor oil leak in the rear main seal" which will need fixing for RWC. I'm not sure what that means.
Any thoughts?
Cheers, Flow
'93 GQ 4.2l diesel: 3" Koni/King lift, 33" Mickey Thompson ATZ P3, 165l tanks, snorkel, roof rack, rooftop tent, CB radio, DIY storage, dual battery setup, & 50l Waeco fridge.
RIP '95 GQ 4.2l petrol/lpg,
RIP '89 Pajero
4th September 2013 02:30 PM
4th September 2013, 02:33 PM
Daily Lurker
$11000 is alot of money... i cant remember how much winnie paid for his, but his looks just as neat and didnt cost that much?
4th September 2013, 02:48 PM
The 747
rusty_nail
I paid more than that but mine was turboed. Looks like a pretty good buy to me!
The Following 2 Users Say Thank You to Winnie For This Useful Post:
Flo-w (4th September 2013), rusty_nail (4th September 2013)
4th September 2013, 02:54 PM
That is big bucks for a twenty year old vehicle. As for the 60ml lift, did he pump 60ml of oil into the shockers Getting the rear main seal is an expensive job, as you would have to split the gearbox from the engine.
4th September 2013, 02:55 PM
Patrol Guru
Can you get RWC with body lift still in? What are the approx. costs if later he wants to turbo (just roughly)?
Thanks, Cameron
No Patrol now - Just good memories!
4th September 2013, 03:15 PM
Wow, so many replies! You guys rock!
60mm is a bit more than the usual 2inch. Is that a RWC problem? Would it even be legal to add the lift later on then? How does that add up with the 50mm body lift (I never had that I think)?
Any idea what that rear main seal job would cost mudnut? That seems to be the major unknown right now.
I haven't seen cheaper GQs with those extras and less than 300,000km. If you have please post them here (mainly VIC but I'm also looking into parts of SA and NSW).
RIP '89 Pajero
Moderator
Tell him he's dreaming mate. It looks clean inside which is Nice.
The rear main seal is at the back of the motor between the motor and the gear box. It is most often replaced while replacing the Clutch. Gear Box must come out to get to it. Fair sized Job.
For $11k you would want 12 months rego and a full RWC with evidence that the rear main seal was replaced and not just cleaned and ignored. I dont believe the Odometer is accurate as it is misaligned slightly which is common with tis model. If the trip meter works intermittently then so will the odometer. Disregard it.
$11k with No RWC he is robbing you IMO.
Check out my Toy -->
Rogue Dung Beetle
The Following User Says Thank You to MudRunnerTD For This Useful Post:
Stropp (5th September 2013)
4th September 2013, 03:18 PM
Moderator
cgm
Not sure on the Body Lift these days?? an MTQ Turbo system fitted is around the $3,500 to $4,000 so buying one with a Turbo is a Good buy. You would get a factory Turbo off a GU fitted up (Less powerful) for maybe around the $2,000 mark.
Rogue Dung Beetle
4th September 2013, 03:29 PM
The 747
You would not get a RWC with the body lift in, but is a 1 hour job to remove. Suspension lift just tell them its 50mm not 60,would be surprised if they actually measured it.
I would suggest getting a few quotes to ascertain how much a rear main would cost. But as MR, said, it is usually a job done with clutch replacement, so that would indicate to me, that it was done quite a long time ago.
