11th July 2010, 11:02 AM
#21
I used to carry around a little 5hp pump with a fire hose which blasted mud off underneath.
But you can only really hook it up to larger water supplies like the local towns fill up points so prob wouldnt work on a standard tap outlet.
Unless there was a tank or you bought up a 500l one or something.
It really works well under the chasis, etc.
11th July 2010 11:02 AM
11th July 2010, 08:42 PM
#22
fire extinguishers work well too but run out of puff too quick
13th July 2010, 08:12 PM
#23
Finished converting all my Headlights and roof lights to HID's
I'd upload a pic but everyone knows how bright they are
8th August 2010, 04:54 PM
#24
Quick Update:
Getting a DTS turbo kit within the next 2 weeks, was going to get a JPC kit but at $4900 to get the same power as a DTS will deliver I couldnt justify spending an extra $1900 for that (a GQ pump will only deliver enough fuel for 100kw!)
11th August 2010, 03:18 AM
#25
Moderator
GQ4.2
Quick Update:
You will love the MTQ / DTS kit. I have no regrets. the $1900 saving you could put into a pump rebuild and get it really pumping!!
Check out my Toy -->
Rogue Dung Beetle
20th August 2010, 10:37 PM
#26
love the two tone paint that mysteriously become three tones
23rd August 2010, 10:29 PM
#27
Yeah the DTS kit should be here later in the week also got a pyrometer on its way as well, should have it all hooked up in a few weeks the next thing after that will be to find another transmission as the one I have wont last (got oil leaking from transfer case and gearbox is abit cruntchy...)
5th September 2010, 06:03 PM
#28
got the DTS turbo kit on and running, love the power and I haven't even adjusted the injector pump yet (need a fitting for the pyro)
just got to get a 3" zorst made up for it and then down the track put a intercooler on it
5th September 2010, 07:33 PM
#29
Go the shorty
6th September 2010, 07:58 PM
#30
put the pyro on today and wound up the fuel, max egt set to 550 deg C
have to say this thing hauls arse now!
