Results 1 to 10 of 10
Thread: Upgrading my brakes
    Expert florix's Avatar
    Casino
    Upgrading my brakes
    Hi all. I am looking at upgrading my brakes and was wondering what my options are. I was thinking of drilled and slotted but don't know what the effects are off road. I have 35s and 4" flexi lift.
    Is there any discs you recommend buying for a 98 GU?
    Another member here is thinking of fitting 4.8 rotors and caliphers as they are bigger,
    IMO I think just slotted is fine , only for the rubbish we put our 4x4 through
    330 Post(s)
    Decent Brake Pads will make a Massive difference too.
    Expert @GUte's Avatar
    Aug 2013
    Beechworth, Nth East Vic
    Do the 4.8 discs/callipers fit inside 15" rims fella's?
  6. #5
    Sep 2012
    Mount Gambier, SA
    43 Post(s)
    Quote Originally Posted by @GUte View Post
    From what I've read, no. But the early model 4.8 brakes do fit with 16" rims
  7. The Following User Says Thank You to BigRAWesty For This Useful Post:
    @GUte (5th September 2013)
  8. #6
    Casino
    I don't have much clearance left between my discs and the rims (16") but yeah I run bendix (or however its spelt) is there any other better brand?
  9. #7
    Sep 2012
    Mount Gambier, SA
    43 Post(s)
    Quote Originally Posted by florix View Post
    Don't think so.. Unless you go a softer pad.. Unsure On that one..
    Advanced
    Feb 2012
    I fitted 4.8 rotors, calipers, splash guards, and master cylinder to my Series 1 TD42T.
    It stops now.
  11. #9
    The master farter
    mudski's Avatar
    461 Post(s)
    Quote Originally Posted by geoffayres View Post
    It stops now.
    Hey Hey its old mate from the dark side who gave me tips on my recovery points a while back! How are ya mate?
    Back on topic. I have read and hear that there is no need to use the master cylinder from the TB48, just the rotors and calipers is all you need. I have been looking at doing this soon as my brakes are due but everywhere I look, no one has the calipers. They all say, good luck in finding them.
  12. #10
    Advanced
    Feb 2012
    Going OK thanks. Hows about you?
    They're not easy to find. I tried a few times, on and off. Takes a bit of luck, 'cos a lot are looking, but well worth doing IMO.
    I fitted the lot, to be sure everything matched. The TB48 master cylinder has a bigger bore than the Series 1 master cylinder.
    I think the bigger bore master cylinder was fitted across the range when TB48's were introduced......don't hold me to it, though.
    Just what I could glean from a bit of research through some specs.
  13. The Following User Says Thank You to geoffayres For This Useful Post:
    mudski (9th September 2013)
