Results 1 to 4 of 4
Thread: sd33 power steering pump bracket
    Jul 2011
    Smile sd33 power steering pump bracket
    Hi guys and girls.I picked up a power steering pump and steering box,thought I had better check it (ease of fitting,etc) and discovered the mounting bracket for the pump is off a petrol engine where i have a sd33.Was wondering if anyone has a mounting bracket to suit my motor or if anyone has piccies of the bracket so I can fabricate a bracket.thanks, all.
    Feb 2011
    Central Coast NSW
    where are you
    Jul 2011
    bray park (Strathpine area) Qld.Probably a bit far to have a look?I think I have worked out part of it.on the side of the timing gear case there is a flat surface with 4 bolt holes.I am assuming there is another bracket which bolts onto that,which I can make.I am not sure where the belt tensioner bolts to.(I found I had part of the bracket less the tensioner arm and the part that mounts onto the timing gear cover)It looks to me like a couple of 90 degree bends on the bracket and bolt on to the water pump??
    Feb 2011
    Central Coast NSW
    pm me your phone number and i will send you some pics
