Results 1 to 7 of 7
Thread: 02 gu III instrument cluster lights
    Beginner Getafix's Avatar
    Aug 2013
    Hi,
    Started my patrol after work and the A/T oil temp, handbrake indicator and battery indicators refused to go off.
    I find it funny that all three decide to come on at the exact same time - any guesses?
    Will inspect each component over the week end but seems like an electrical glitch more than anything.
    Just changed the oil, oil filter and air filter yesterday (15 w 40). Spoke to an engineer friend of mine who said that that grade is fine, any comments?
    Any help would be appreciated.
    Adam
    Bitumen...Another waste of public funds
    2002 GU III A/T Gold Grenade
    Expert janderson's Avatar
    Bearii Vic
    3 Post(s)
    I had instrument cluster lights come on/off for no reason. Turned out to be alternator. Check voltage at battery to see if its working.
    1st G60 Then MQ Now GU
  4. The Following User Says Thank You to janderson For This Useful Post:
    Getafix (26th August 2013)
    from what Ive read on other threads, I'd also say your alternator. But maybe one of our more learned friends can confirm.
  6. The Following User Says Thank You to Clunk For This Useful Post:
  7. #4
    Patrol Freak gaddy's Avatar
    redlands
    As above mine did the same when the alternator died
    Steve
  8. The Following User Says Thank You to gaddy For This Useful Post:
  9. #5
    Aug 2013
    Thanks guys, will check the alternator sometime tomorrow or probably over the weekend.
    Adam
  10. #6
    Aug 2013
    Checked the battery finally and was reading 11.3 when the engine was on with the heater and fans off.
    That being said would replacing the regulator help fix this rather than the whole alternator? (Assuming it is a problem with the alternator and not something else)
    Also, and please forgive the ignorance,
    1. Is the 100amp fuse that the b+ is connected to, locked by a screw?
    2. Would the 100 amp fuse also mean that the alternator has a 100 amp rating?
    Adam
  11. The Following User Says Thank You to Getafix For This Useful Post:
    dirtygu (30th August 2013)
  12. #7
    redlands
    Take your voltage from the alternator , not thr battery , I had mine rebuilt $300 , exchange was about the same price, good time to change all the belts , keep the old ones as spares
    Steve
  13. The Following 2 Users Say Thank You to gaddy For This Useful Post:
    Getafix (30th August 2013), threedogs (30th August 2013)
