19th September 2013, 05:46 AM
#21
MudRunnerTD
Holy sh1t!!!! Looks sweat!!!
X2. They don't look that heavy in the pics..
19th September 2013 05:46 AM
19th September 2013, 07:26 PM
#22
Patrol Freak
Got the passenger side in this afternoon. Wasn't quite that awesome an experience I was after, took a little longer than I expected, but it looks solid. Will try and fit the drivers side tomorrow followed by pictures.
The Following User Says Thank You to Parksy For This Useful Post:
MudRunnerTD (19th September 2013)
20th September 2013, 05:14 PM
#23
Patrol Freak
Drivers side installed. Will post up pics soon. Some tips for the job, get ahold of a 12mm and a 17mm ratchet spanner. Will need vice grips to remove the captive bolts that hold the brake lines to the spring hats. The u bolts are a pain to torque down but a ratcheting spanner should make this a little easier. I spent an hour on them but I only had a regular open ended spanner. There are 6 bolts that hold the brace to the spring hat and on the drivers side, the middle ones will need trimming, otherwise they will extend 5-8mm past the brace and push the brake lines up. Otherwise not too bad to install.
The Following 3 Users Say Thank You to Parksy For This Useful Post:
BigRAWesty (20th September 2013), GUtsy ute (20th September 2013), Stropp (20th September 2013)
21st September 2013, 01:34 PM
#24
Patrol Freak
21st September 2013, 01:39 PM
#25
Do they recommend jacking the body to relax the mounts before tightening the 3 middle adjustable bolts?
21st September 2013, 01:44 PM
#26
Patrol Freak
megatexture
I printed off the instructions and there was no mention of doing this. Everything is installed loosely, then everything is done up bar the tensioning bolt or those 3 you mentioned. The tensioning bolt is torqued just enough to put some preload on the spring hat, then the 3 get torqued to hold it in place.
