Results 1 to 10 of 18
Thread: Question re Wire or Rope. On New winch.
    Expert rafa's Avatar
    Jul 2013
    I am about to instal a new 12000lb winch.
    Question is old school wire or this flashy looking lighter rope stuff?
    During the wet season up here it will earn its money, so i guess I'm saying it won't be a decoration.
    Your thoughts as to which way to go? I'm thinking Ironman cause I've spent way too much getting this Ol girl where I want it to buy a warn etc..
    Marty
    2002 4.2TD ex Telstra
    330 Post(s)
    Rope for sure. Light, Safe, easy to use.
  4. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    rafa (29th August 2013)
    Legendary happygu's Avatar
    Another for the synthetic rope....get the best quality one you can, and you won't go back.
    Mic
  6. The Following User Says Thank You to happygu For This Useful Post:
  7. #4
    Advanced Monty_e's Avatar
    Brisbane, Northside
    Plus one for synthetic rope!
    2003 GU ST ZD30 Auto
    Pre NADS: Pyro & Boost Gauges, EGR block plate, Catch-can, Multi Stage Boost Controller (Dawes valve) & Needle Valve ordered!
  8. The Following User Says Thank You to Monty_e For This Useful Post:
  9. #5
    Apr 2011
    Melton
    I prefer rrope but due to the $$$ ended up with wire. if you can afford the rope go for it.
    With wire you have to ensure that there are no crossovers when you are winching as these will creat flatspots and could eventually cause a faulre.
    I have seen rope flattened by repeated use - but was still safe to use.
    Plus wire can be hard on the hands
    Plus is does not float
  10. The Following User Says Thank You to GQ TANK For This Useful Post:
  11. #6
    Quote Originally Posted by rafa View Post
    Marty
    I've got the ironman winch with rope and cannot fault it.
  12. The Following User Says Thank You to Winnie For This Useful Post:
    rafa (2nd September 2013)
  13. #7
    Go the Plasma style rope and buy the slide on protective sleeve as its not very UV friendly.
    I have seen canvas covers for winches on Ebay
  14. The Following User Says Thank You to threedogs For This Useful Post:
  15. #8
    Oct 2011
    Rope is safer and easier to use as well being lighter.
    Make sure you give it a wash every now and then, just like a snatch strap. Dirt can get into the fibres and cause wear. It is a good time to make sure the rope is laid correctly on the drum too.
  16. The Following User Says Thank You to joeker For This Useful Post:
  17. #9
    As you know weight is your enemy on outback roads so by using Dyneema style rope and a hauwse fairlead
    you could be losing up to 15KG of weight off the front end , has to be a good thing, take your old winch cable
    and get "eyes" spliced in each end makes a great winch extension, if you need it.
    Ironman have a great warranty, no questions asked
  18. The Following User Says Thank You to threedogs For This Useful Post:
  19. #10
    Legendary NP99's Avatar
    Feb 2013
    Broadford VIC
    I'm old school and like wire. Rope has its disadvantages as does wire!
    1999 GU 4500 dual fuel
    Il dado è tratto
  20. The Following User Says Thank You to NP99 For This Useful Post:
