Results 21 to 30 of 35
Thread: mild resto underway on my first gq
    Aug 2013
    brissy
    .. android app not uploading pics sorry .. Update nearly there. Bloody marathon effort but it's painted just have to clear it
    Aug 2013
    brissy
    Aug 2013
    brissy
    Advanced Nowlzy's Avatar
    Feb 2018
    Gday timeslayer, the patch in the floor, did you just bog it up or is it a patch / sheet metal? I’m in brisbane awaiting arrival of a 1988 GQ which reported hole through the floor so expect will be doing a similiar repair. Just wondered if you found an easy solution to fix and be road worthy?
  6. #25
    Quote Originally Posted by Nowlzy View Post
    Depending how big the hole is I would weld in some panel steel or g9 to the wreckers with an 18v grinder and cut out a piece of floor.
    If it is smallish then cut it round with a hole saw and put a rubber bung in it and No one will ever even notice. You can get bungs to 50mm
  7. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    Nowlzy (10th February 2018)
  8. #26
    Feb 2018
    Any point in trying to repair a rusted firewall?
  9. #27
    think body swap..seriously
  10. #28
    192 Post(s)
    Yeah x 2. Mine had rust everywhere and in the firewall ended up sing a body swap. Not sure how easy the firewall would be to repair but would imagine being an absolute pain in the butt and not sure how good you could do it too. . . Probably come back down the track.
  11. #29
    I reckon you'd need to take the cab off and weld in a new panel. While the cab's off you might as well chuck a new cab on really.
  12. The Following User Says Thank You to Winnie For This Useful Post:
    Nowlzy (22nd October 2020)
  13. #30
    Feb 2018
    Thanks guys, I’ve managed to pick up a cheap GQ with clean body; it even runs with 320k on the engine!
