Results 1 to 7 of 7
Thread: 07 winch bullbar on 02?
    Beginner Getafix's Avatar
    Aug 2013
    On a shoestring budget with minimal tools and even less knowledge. Found a winch bullbar for a reasonable amount from reasonable bloke who said the bullbar from the 07 will not fit my 2002 GU III. Would that be correct?
    Adam
    Bitumen...Another waste of public funds
    2002 GU III A/T Gold Grenade
    Legendary happygu's Avatar
    Adam,
    I believe the bar itself will fit, but the gaps will all be wrong.....
    The later grill is deeper, necessitating a bigger cut-out in the bar itself to make the bars fit the new ones.
    If you don' t mind a bit if a gap, then go for it, but I think that you should be able to find the bar you are after quite easily.
    Mic
    Aug 2013
    Thanks Mic, will keep hunting then.
    Patrol Freak trekster's Avatar
    Nov 2012
    Coffs Harbour, NSW
    Check gumtree too as I see them come up a fair bit on there!
    Cheers,
    Eric.
    1998 GU RD28T: RIP
    Hello 2012 GU CRDZD30
  6. The Following User Says Thank You to trekster For This Useful Post:
    Getafix (24th August 2013)
    43 Post(s)
    Sorry, miss read your looking for a winch bar..
    Have you looked at cradles..
    Aug 2013
    not yet, should I be looking at cradles first?
    was going at it one part at a time its a looooooong list
    1> Panhard rod - first step for nasty wobbles
    2> N.A.D.S.
    3> 2/3" lift kit (got 270000ks on the odo and no sag - she's pretty fit for an old girl)
    4> MUDDIES
    5>Winch compatible bull bar
    6> Winch
    7> Roof Rack
    After the panhard rod and N.A.D.S. its in no particular order of preference
    Also going to the local wreckers to see if I can see something worth salvaging
    Nads first, or at least put some gauges in so you can see whats happening
    Lift you do last so you can tailor spring weights to suit your load
