Results 1 to 10 of 13
Thread: Splicing a Dyneema Winch Rope
    Hey guys i have had to shorten my rope and went looking for the best option to install the eye back in the end and this is a Winner!
    http://www.animatedknots.com/brummeldemo/
    Helped me. Hope it helps You. Simple
    Cheers MR
  2. The Following 9 Users Say Thank You to MudRunnerTD For This Useful Post:
    AB (23rd August 2013), cgm (23rd August 2013), Chubba (8th April 2016), megatexture (23rd August 2013), MEGOMONSTER (23rd August 2013), Robo (8th April 2016), Sherro (23rd April 2016), threedogs (24th May 2018), Touses (24th May 2018)
    brisbane
    That looks nice and easy, how was it feeding the rope down the inside ? I imagin that parts annoying
    Quote Originally Posted by megatexture View Post
    yeah was not to bad. My rope is use so probably be easier in brand new rope. second hand rope is a bitch!
    I watched this Video too and then used the first half of this vid ie. the taper and tape it up then used the top link to build the splice. All good and pretty simple.
    https://www.youtube.com/watch?v=Q22wgYZL9f0
    If your at home though then making this little puller will make the final part of the thread much easier.
    http://www.animatedknots.com/longbur...matedknots.com
  7. The Following User Says Thank You to MudRunnerTD For This Useful Post:
  8. #5
    Hardcore 04OFF's Avatar
    Brisbane,QLD
    12 Post(s)
    I replaced my thimble using another one of this guys videos about a year ago, very helpfull.
  9. The Following User Says Thank You to 04OFF For This Useful Post:
  10. #6
    I have some spare 19mm plasma I use as a GP type of rope around camp. I have only gone in and out about 4 times as the more pressure the tighter the grip.
    Has not let go but I use mainly for logs around camp, I'll put up a pic, I only fitted a rated hook to each end, I could of course feed it down the centre
  11. #7
    Hardcore
    central coast nsw
    Thanks MR great links.
    I'm constantly impressed how much info you can pick up on this forum
    Think it's worth mentioning --
    Reading the links attached printed info "could" help you do an even better job repairing your own gear.
    EG--how kinks, knots, twists, bend etc can weaken a rope.
    so called "best practice" will help keep rope integrity & lesson the chance of mishaps even further.
    not preaching, personal experience trying to repair a rope well on the first attempt does breed confidence.
    IF IT'S NOT A NISSAN.
    THEN IT'S A COMPROMISE
  12. The Following User Says Thank You to Robo For This Useful Post:
    MudRunnerTD (8th April 2016)
  13. #8
    Locked Brummel or a Brummel seized with whipping or heat shrink is the the way to go with synthetics
  14. #9
    Heat shrinking not too hot for the rope??
  15. #10
    No way. Doesn't take much temperature to shrink it.
