16th August 2013, 07:48 AM
Gas struts - Good brands?
Its seems that nearly all GU owners have trouble with the bonnet gas struts. I'm about to replace mine but thought I'd ask if anyone can recommend a decent brand that will last a little longer.
Cheers, Scotty.
16th August 2013 07:48 AM
16th August 2013, 08:13 AM
I just bought mine off eBay, was like $35 posted, imo they are all gonna be around the same, it's not like shocks were you go for the better brands.
Cheers,
Eric.
1998 GU RD28T: RIP
Hello 2012 GU CRDZD30
The Following User Says Thank You to trekster For This Useful Post:
MudRunnerTD (16th August 2013)
16th August 2013, 09:36 AM
Sweet, cheers for that Trekster.
16th August 2013, 09:37 AM
They also come in different pressures so make sure you get the correct pressure
and mount them the correct way , which is black piston side down, keeps them lubricated
Pressure wise they would need to be 400Nm minimum, not sure what OE are.
100Nm = 10Kg approx
23rd August 2013, 07:26 PM
threedogs
100Nm = 10Kg approx
With the ebay ones advertised here they only say GU 1997 on so if pressure is an issue wil these do?
Got to do my '05s struts.
23rd August 2013, 10:38 PM
Patrol Guru
outback
Should be fine.
Here is a link to the ones I bought.
http://www.ebay.com.au/itm/Bonnet-Ga...50df4aa&_uhb=1
Only need to lift the bonnet a little bit now and the struts do the rest.
Also on the struts themselves they are marked for which way up/down.
Evo
Cheers,
Evo
23rd August 2013, 11:49 PM
Thanks. I had been looking at those struts but I was not sure if that were OK. Seems though they do a good job.
28th August 2013, 09:53 PM
#8
Ordered up, will let you know how go.
9th September 2013, 10:26 PM
#9
Gday, I replaced mine with Nissan Maxima struts. Was told they higger pressure coz of the longer canterlever of the Maxima bonnet.
Paid $100 but work gr8. Hold bonnet up in any position.
Daz
10th September 2013, 10:50 PM
#10
Evo
Bought these and fitted yesterday.
They seem to have a bit less articulation on the ball but fit and work fine
I don't have to use the jack handle as a bonnet strut anymore!!
Just got to fix the latch bar in the bonnet now!?
Dru
2004 GU Ute 4.2 turbo intercooled leaf rear with a pod. A project!
Member of the Podder's Community... DX Grunt, Cuppa, GUTsy, TwinDiffs, Macca, Nowoolies work truck, GU Camper, TonyHoughton, GrumpyOldFart
