15th August 2013, 09:21 PM
Advanced
2nd row seat stuck
Hi Guys,
One of my 2nd seats is stuck and wont lift up.
Is there a trick or tip on how to get the seat up or off so that i can see whats wrong with it.
I unbolting the bolts on the front of the seat but couldnt get the seat off at its still locked to the bottom latch.
any help would be appreciated.
2009 ST-L with a few goodies.
15th August 2013 09:21 PM
15th August 2013, 09:56 PM
Moderator
crazyenough
Hi Guys,
Mmmm bugger! And you can't get a spanner on the back mount? What happens when you tug the strap? Can you feel the latch open or its fully jammed?
Check out my Toy -->
Rogue Dung Beetle
15th August 2013, 10:52 PM
Advanced
Yeah a bugger of a issue.. Feels like the cable is pulling on the latch but its not disengaging.
Might give it another go at trying to unbolt the latch hook.
15th August 2013, 11:12 PM
Moderator
Get one of your kids to jump on the seat while you pull the cable a few times and see if its not just a bit tight. Otherwise reach under and manipulate it with a screw driver and see if you can actuate the clasp as the cable would??
Rogue Dung Beetle
15th August 2013, 11:13 PM
Moderator
Oh and I alway find swearing at it while giving the thing a good belting can achieve great results
Rogue Dung Beetle
The Following User Says Thank You to MudRunnerTD For This Useful Post:
BigRAWesty (26th August 2013)
16th August 2013, 01:29 PM
Advanced
Tried prying it with a screwdriver as i pulled on the lever as well not no luck either... will try and get someone to jump up and down on it and see if it budges.
If not alot of swearing maybe the goer...then hit it with a hammer.
16th August 2013, 01:37 PM
Tongue out the side works for me, you haven't
jammed anything underneath?
16th August 2013, 01:56 PM
Wasn't there an easy fix for this? I seem to remember someone else had this problem late last year. I'm stuffed if I can find it with the search function...
16th August 2013, 02:15 PM
Think I remember that thread wasn't the lever stripped out preventing the cable from moving, you have two levers
one to lower the back the other to release the base.
16th August 2013, 02:21 PM
I found a thread where Malcom gave us a heads up that the strap comes off, it must be what I was thinking of. Bad memory.
