Page 256 of 262 FirstFirst ... 156206246254255256257258 ... LastLast
Results 2,551 to 2,560 of 2619
Thread: The Knife Thread
  1. #2551
    Quote Originally Posted by gubigfish View Post
    Was looking for an all round knife sharpener for when I help the old man killing a calf etc for meat, find the knifes go blunt quickly while skinning the animal and reckon there must be a good all round tool for the job.
    Might be better off using a decent steel like the F.Dick ones,
    http://www.ebay.com.au/itm/Vintage-F...cAAOSwJ7RYYHbu
  2. The Following User Says Thank You to threedogs For This Useful Post:
    gubigfish (4th January 2017)
    Aug 2014
    Perth
    10 Post(s)
    The old man puts the knives on the dry part of the wet and dry grinder he has on the workshop but doesn't give a good edge see lots of burrs and pits in it.
  5. #2553
    Feb 2012
    "Hiding Under Your Bed!"
    30 Post(s)
    I carry 1 of these and not had a problem with the blades at all;
    https://www.ebay.com.au/itm/171562400828
    "Never under estimate the power of the tap, let it flow through you"
    www.swat4x4.com
  6. The Following User Says Thank You to oncedisturbed For This Useful Post:
  7. #2554
    Still think if you are processing a whole beast in the field then a decent steel would work.
    Buy a decent Arkansas whetstone [soft] and create an edge which you can then maintain with the steel.
    What size knife you use will determine what you need to maintain the edge.
    Are you using butchers knives for example ???
  8. The Following User Says Thank You to threedogs For This Useful Post:
  9. #2555
    Mar 2016
    Nandewar Ranges, NSW
    10 Post(s)
    That brought back some memories TD (good & bad), used to work in Abattoirs & Boning rooms back in the day. Used many F.Dick knives & a steel the same as this one rubbed down with 1200 wet & dry to near a smooth finish.
    http://www.ebay.com.au/itm/Vintage-F...3D302176947737
    Had a flat Victorinox steel as well. Couple of hits on it then a couple on the F.Dick. Could work the boning knives all day without having to put them on the stone.
  10. #2556
    Quote Originally Posted by VK2FMIA View Post
    Thats what I mean for the bigger jobs like processing a beast a steel is the go.
    When I was travelling years ago I learnt quickly how to use a knife as you could get well
    paid work in most ab's. I worked at the Fremantle and Alice Ab's loved every minute,,lol
  11. #2557
    brisbane
    Hi 3D I'm looking for a good skinner but I don't want to break the bank , have you got any suggestions
  12. #2558
    brisbane
    This is along the lines I'm thinking
    http://www.ebay.com.au/itm/Gerber-MO...3D322272905168
  13. #2559
    Quote Originally Posted by megatexture View Post
    Hi Mega been a while hope all is well, any of those Gerber field knives would be ok
    What will you be dressing???
  14. #2560
    brisbane
    Yea mate all is well just been busy with buisness and family, I'll be dressings a large buck if I can get close enough for a good shot with my bow. Got one of his antler from last year and it's longer then my arm. Looking forward to this .
