Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Stupid question
    Perth WA
    61 Post(s)
    Quote Originally Posted by Dark Knight View Post
    Hi guys
    This is going to sound like a stupid question, but do GU diesels 'need' two batteries. I've just bought one, it has two batteries under the bonnet and a TJM dual battery 'system', but I just wanted to make sure before buying a deep cycle one, that I don't need two 12V batteries to start the diesel beast.....
    Mate there is no such thing as a stupid question here, we all are learning every day from each other, that whats makes our forum one of a kind
    If any members require assistance in anything regarding this forum, just let me know via a PM and I will help you in any way that I can.
  2. The Following 3 Users Say Thank You to Woof For This Useful Post:
    2TROLLFAM (6th September 2013), Steve4wdin (8th August 2013), Stropp (8th August 2013)
    Aug 2013
    Awesome thanks for the reply guys. So next question is I assume the plug in the boot is wired up to the main (starter), so I'd need to change the wiring (to wire it to secondary) to use it with a WAECO? Or does a WAECO run straight to the battery itself?
    I haven't bought a fridge yet, but in the market.... :-)
  5. #13
    Is your rear panel like this,
    to power this panel power comes off my Aux battery
    You would want your fridge to be powered by the AUX battery
    otherwise you will flatten the start battery
  6. #14
    Expert Steve4wdin's Avatar
    Feb 2012
    Western Sydney
    I would not try run a fridge of that plug. The wires are to small a gauge for a fridge and yes that plug is wired to main battery. It is only really good for maybe LED lights etc.
  7. #15
    Mar 2013
    Letting the motor run while using the winch might be a good idea, but not always possible (e.g. unexpected deep mud). I would therefore not connect the winch to the same battery, to ensure it is possible to start the engine when out of trouble.
  8. #16
    Patrol God Sir Roofy's Avatar
    TRAFALGAR VIC
    35 Post(s)
    Quote Originally Posted by mtiehatten View Post
    letting the motor run while using the winch might be a good idea, but not always possible (e.g. Unexpected deep mud). I would therefore not connect the winch to the same battery, to ensure it is possible to start the engine when out of trouble.
    common sence plays a big part in 4x4ing stop and get out and check the depth of any creek, river, bog that your not sure of
    as said its not wise to winch of the aux battery and if your stuck that bad and deep you,l most likely burn the winch out
    or your battery will flatten very quickly,i always use the crank battery for the winch with the motor running
  9. #17
    @ Steve I don't run my Engel from that panel only some camp lights if that.
    My Engel is hard wired direct to the AUX battery via a thermal cut out switch.
    It goes through a carling style switch on centre console to a 50amp Anderson plug.
