Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Wiring question
    brisbane
    Take 10 mins to run one though lol, that is dodgy ! I don't like to bum power off any stock supply unless its just switching a relay.
    Aug 2013
    Thanks guys - I am going to remove it, i thought it was for the rear 12v fridge plug, but my mate thinks that is standard... I also wasn't able to get any voltage from it.. I am no expert, infact new to the use of a multimeter. I could get readings from other cigarette sockets.. so not sure.
    There are NO other accessories, only a 2 way i installed and I used another power source.
    Thanks guys I thought it was dodgy and glad to see i wasn't wrong... I pray this was the guy doing it himself and there isn't an auto elec doing work like this...-- it has to be.
  4. #13
    Aug 2013
    OK found out what it supplies power to - the eletric windows!
    There must be something up with the original wiring - any suggestion on how to re wire it properly? Surely there is a standard place to get the power from?
  5. #14
    Legendary happygu's Avatar
    Quote Originally Posted by Gregsway View Post
    That shouldn't be the spot where the power windows come from ..... will check the service manual ....
  6. #15
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    There is a main 40 amp fuse in the fuse box under the bonnet and a circuit breaker mounted near the relay in the LHS kick panel, inline with the bottom of the glovebox.
    Also check fuse number 8 (7.5 amp fuse) in the fuse box inside the vehicle. The ignition needs to be turned on for the windows to work.
  7. The Following 2 Users Say Thank You to Yendor For This Useful Post:
    Gregsway (13th August 2013), MudRunnerTD (9th August 2013)
  8. #16
    I don't know why your wiring has been bodgied up like that but have a very close look at the condition of your fuse box as per the photos in this thread; http://www.nissanpatrol.com.au/forum...712#post161712
  9. The Following User Says Thank You to YNOT For This Useful Post:
