5th August 2013, 06:52 PM
05 GU advice.
Just taken ownership of an 05 3.0, and thirsty for any advice on these units. The engine is stock apart from a fuel/water separator and a DP chip. I would like to fit an EGR block, catch can and boost gauge. From the little research I have done, these seem to be the first things I should be doing.
Your thoughts??
5th August 2013 06:52 PM
5th August 2013, 06:59 PM
Get an EGT gauge and boost gauge first
The Following User Says Thank You to Limmy For This Useful Post:
macca86 (5th August 2013)
5th August 2013, 07:02 PM
How's the serenity
Bigger exhaust system also makes a massive improvement in more ways than one .
The price of excellence is dicipline , the cost of mediocrity is dissapointment .
5th August 2013, 07:06 PM
Thanks Limmy, any suggestions on type, or brand? I'm a mechanic, so fitting them is not a problem although my experience on automotive stuff is way out of date, decent instructions would be a definite bonus.
5th August 2013, 07:09 PM
Thanks Boots, I do want a better exhaust but I'm not sure how the DP chip affects this. I'm guessing the vehicle would need to be dyno'd to ensure the turbo doesn't get damaged due to incorrect back pressure.
5th August 2013, 07:16 PM
you want EGT gauge in CELCIUS. And boost gauge im PSI format.
Most of forum members go VDO, autometer , autron. I personally got racetech brand.
Just dont buy cheap gauges.
