5th August 2013, 11:53 AM
Tire Rack US tire company
Hi guys
if this has been posted before you can delete it but a mate put me on to this website in the US and they have really good brands cheap just not micky thompsons but you have to get a courier mob to deliver hope this may help
http://www.tirerack.com/tires/tire-brand.jsp
The Following User Says Thank You to 93patrol For This Useful Post:
threedogs (5th August 2013)
5th August 2013 11:53 AM
5th August 2013, 01:30 PM
just be wary about anything over $1000 aus as you'll get stung 10% import tax on top of it all. In most cases when I've bought from them this is still a better alternative to local resellers but with the weakening aus dollar its going to get a bit tighter.
shipito.com etc are usully good for freight forwarding out of the US.
The Following User Says Thank You to XT43 For This Useful Post:
93patrol (5th August 2013)
5th August 2013, 01:32 PM
if its like buying from china they will make it look like you only spent $50 when you spent $5,000 lol
2nd October 2013, 12:24 PM
Hi guys..I have contacted tirerack and am planning to buy new set of wheel for my GQ. A rep from Tirerack ask me to provide: not just bolt circle, but also hub diameter and extension, brake caliper clearance, offset, load capacity, pad depth, etc. Can anyone help me regarding this matter? Your help is greatly appreciated. Thanks!!!
2nd October 2013, 02:15 PM
Just about to jump into my next Patrol. A 2001 GU II TB45E .
WARNING!: Do not ever use a towball as a recovery point. They are not rated and can become a deadly projectile during a recovery if they snap off, and they have done so with tragic results in the past.
4th October 2013, 12:39 AM
Thanks rkinsey!! Will read through it..
I am planning on getting wheels 15x8 with offset of -19mm and backspacing of 3.7 inch..will it fit my gq without any lift?
