31st July 2013, 03:08 PM
Gq patrol front efi calipers
Hi all
Does anyone know if the twin pot caliper pistons on the gq efi are interchangeable with gu patrol twin pistons? Only reason I ask is nissan want $90 each for the gq where as eBay has 2 for about 40 but listed for a gu patrol.
http://www.ebay.com.au/itm/2-x-Front...4bf69ec&_uhb=1
Thanks all
Andy
31st July 2013 03:08 PM
31st July 2013, 03:56 PM
I got a response from the eBay seller, he said they won't fit. If anyone knows where I can get the pistons, apart from nissan, then I'll be your mate for life.
5th August 2013, 07:52 PM
Parksy,
sorry to be so slow. Don't have a clue as I've never had a prob. with the caliper pistons on two models but if the pistons themselves are OK, as I'd expect, then the rubbers may be part of a recon. kit. Mind you, if the cylinder is scored and stuffed you're really back to square one. Have you looked up recon. kits? What about wreckers as a last try?
May need a pointy stick to push it uphill with.
Good luck
Col
The Following User Says Thank You to Col.T For This Useful Post:
7th August 2013, 03:32 AM
You may find your local auto shop like Bullseye or Auto-pro may surprise you with price.
notice alot of stuff on ebay getting to be more like retail these days .
Bursons are usually alot dearer haven't bought anything off em in a long time to pricey
IF IT'S NOT A NISSAN.
THEN IT'S A COMPROMISE
The Following User Says Thank You to Robo For This Useful Post:
7th August 2013, 04:24 PM
Thanks guys. I ended up buying the genuine nissan unit. I only needed the one because when I pulled the front calipers apart, I found that one of the pistons was replaced with an aftermarket unit, but it had a different profile on it, meaning different surface area which meant the 2 pistons within the caliper were extending at different rates. Not good. But sorted now.
If the pistons I listed were going to fit, I was going to just buy four.
