Results 1 to 6 of 6
Thread: Belt Tensioner Fix..... I think
    Advanced Remmy's Avatar
    Feb 2013
    Springwood NSW
    On a facebook page someone posted this and was wondering what others thought of the idea.. I think the only problem you could have is over tightening and overload the pressure on the bearings on the alt and ac...
    comments?
    Remmy
    The master farter
    mudski's Avatar
    461 Post(s)
    Using a micro v belt spring loaded tensioners are needed in this case. Going that way in the pic I would think the belt wouldn't last too long.
    North brissy
    Imagine it would be hard to get at too.
    Legendary
    Properly adjusted I can't see it being a problem.
  6. #5
    The master farter
    mudski's Avatar
    461 Post(s)
    Micro v belts are a lot more flexible than a standard v belt and also the distance around the pulleys it has to travel is a lot longer. A spring loaded tensioner is needed for these belts because of the distance the belt is traveling, the many straight sections between each pulley creates a lot of vibration and therefor using a spring loaded tensioner acts like a shock absorber for these vibrations, and also keeps the correct tension on the belt, not too much and not too little. You take this away and I would guess the belt would either just jump off the pulleys or destroy itself. Not to mention the stress put on all the other pulley brackets.
  7. #6
    Patrol Guru Morton's Avatar
    Sydney West
    x 2 on this comment, it is a good thing to have in your kits for when the tensioner fails in the middle of no where
    2002 3L GU Patrol, 2" lift, 33's, snorkel, dual battery, sliders, DVD, bluetooth
