3rd August 2013, 02:34 PM
3rd August 2013 02:34 PM
3rd August 2013, 03:27 PM
You have the right spot, looks like your plate is wrong. Is it definitely for a crd zd30? I would just use gasket as template to re-drill the holes
2012 GU8 Polar White Auto ST Patrol, Factory Bull bar, Scangauge 2, EGR blanked, Milford cargo barrier, Outback ideas recovery points, Micks retrofit HID 3 inch projectors with Osram bulbs and 55w ballasts, GME TXE3420, Sidewinder dual battery with monitor, Windcheetah 2.0m alloy rack, Suspension Stuff 2" Flexy lift with SS Monotubes, MT ATZ 4 ribs 265/75R16 on black Dynamic rims, Custom rear draws with fridge slide.
3rd August 2013, 03:37 PM
Just mark [scribe] the plate then file to suit. Clean your IC as well if its oily.
3rd August 2013, 05:21 PM
http://www.ebay.com.au/itm/EGR-Blank...item33843c1ba9
looks more like this one .this is mudski's add on ebay . he can sort you out
3rd August 2013, 07:16 PM
Yeah I will have to hit Mudski up cause I ordered that one off him!
2008 GU ST Bog stock and no smoking barrels!
3rd August 2013, 09:36 PM
Check the other end of the pipe mate. Exhaust end. I have the plates made for the intake end anyway. Just pm me your addy and I'll send ya one. That plate you have is more common on the CRD 3.0L Navara's. Very few Patrols used this one.
Also the new plate I'll send ya goes where the EGR pipe meets the EGR. Second pic in your post.. But I suppose you could put it closer to the engine. May not matter...But I would go before the EGR itself....
5th August 2013, 12:40 PM
The Following User Says Thank You to Beni C For This Useful Post:
Kennyj1976 (26th April 2014)
