Results 1 to 7 of 7
Thread: CRD EGR Block Help! While its in pieces!!
    Apr 2013
    Mount Nasura
    Exclamation CRD EGR Block Help! While its in pieces!!
    Hi guys,
    Quick one, I have got the thing in pieces doing some repairs to the fuel system so I thought I would try and do the EGR block at the same time while its all apart and easy to get to but I wanted to check where the plate goes.
    I beleive that it was to go on the engine side but the plate I have doesnt match up to the bolts holes.
    Please have a look at the pics!
    Engine side where I thought the plate goes and the gasket came out of.
    Back end of the EGR plumbing, looks like the bolts holes might line up here.
    Plate and gasket
    Gasket on plate
    Any help, greatly appreciated!!
    2008 GU ST Bog stock and no smoking barrels!
    Expert Blacklotusdog's Avatar
    You have the right spot, looks like your plate is wrong. Is it definitely for a crd zd30? I would just use gasket as template to re-drill the holes
    2012 GU8 Polar White Auto ST Patrol, Factory Bull bar, Scangauge 2, EGR blanked, Milford cargo barrier, Outback ideas recovery points, Micks retrofit HID 3 inch projectors with Osram bulbs and 55w ballasts, GME TXE3420, Sidewinder dual battery with monitor, Windcheetah 2.0m alloy rack, Suspension Stuff 2" Flexy lift with SS Monotubes, MT ATZ 4 ribs 265/75R16 on black Dynamic rims, Custom rear draws with fridge slide.
    Just mark [scribe] the plate then file to suit. Clean your IC as well if its oily.
    Expert Limmy's Avatar
    http://www.ebay.com.au/itm/EGR-Blank...item33843c1ba9
    looks more like this one .this is mudski's add on ebay . he can sort you out
    Apr 2013
    Mount Nasura
    Yeah I will have to hit Mudski up cause I ordered that one off him!
    Check the other end of the pipe mate. Exhaust end. I have the plates made for the intake end anyway. Just pm me your addy and I'll send ya one. That plate you have is more common on the CRD 3.0L Navara's. Very few Patrols used this one.
    Also the new plate I'll send ya goes where the EGR pipe meets the EGR. Second pic in your post.. But I suppose you could put it closer to the engine. May not matter...But I would go before the EGR itself....
    Beni C (5th August 2013)
  9. #7
    Apr 2013
    Mount Nasura
    Will PM ya Mudski
  10. The Following User Says Thank You to Beni C For This Useful Post:
    Kennyj1976 (26th April 2014)
