Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Sub Tank Switch by pass
    Unafordable
    4 Post(s)
    Here ya go ==>
  2. The Following 3 Users Say Thank You to Rumcajs For This Useful Post:
    Ian2011 (9th January 2014), MudRunnerTD (10th January 2014), PMC (12th January 2014)
    Expert Ian2011's Avatar
    Sep 2011
    Australia
    Thanks for that Rumcajs, guess I have to try to find my fault now, these diagrams will go a long way to help.
    6.5 Chevy, roof rack, uhf, Spotties, dual batteries, ARB Bullbar, 12, 000lb winch, (unfortunately not Warn) Safari snorkel, Dieselgas conversion, 2in lift, engine watchdog fitted, boost/EGT guages, front elokka fitted, rear power supply mods, turbo timer, dual wheel carrier rear bar.
  5. #13
    Sep 2011
    Australia
    Don't suppose you have the diagnostic procedures to check the fault codes.
  6. #14
    Unafordable
    4 Post(s)
    Quote Originally Posted by Ian2011 View Post
    Now who is pushing some luck, LOL
    here ==>
  7. The Following 3 Users Say Thank You to Rumcajs For This Useful Post:
    Ian2011 (12th January 2014), MudRunnerTD (10th January 2014), PMC (12th January 2014)
  8. #15
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    I too wish to rewire this circuit, I am now having the same issue as numerous people have brought up about the Sub tank light remaining on all of the time. I have done the "remove power from battery" numerous times in my trip from Wodonga to Darwin to try and utilise both tanks but it's getting a bit ridicules doing this on almost a daily basis. Has anyone actually solved this problem yet, reading all of the other threads on this topic has not given any info other then cleaning terminals, disconnecting the battery or fitting an additional earth strap. What is the purpose of the sub tank controller behind the radio, if the tank has to be manually transferred anyway, why would it need a controller apart from pumping some fuel between tanks on start up, can this be removed from the circuit to provide a direct link to the transfer pump whilst using the existing switch.
    Has anyone actually done this modification or even come close to solving this issue.
    Have you installed an earth strap to the chassis?
    You can wire a simple on/off switch to run the fuel transfer pump if you like.
    The controller is to make sure you don't overfill the main tank and that fuel transfer stops when the sub tank is empty so you don't run the fuel pump dry.
    Do you still have standard fuel tanks or long range tanks fitted?
  9. The Following User Says Thank You to Yendor For This Useful Post:
  10. #16
    Sep 2011
    Australia
    I haven't actually put an earth strap on, was more interested in actually discovering what caused the problems rather then just putting a 'fix' on. In saying that I have not had the light come on for three days since I stopped letting the turbo timer switch the car off. Running a simple on/off switch, that's what the switch on the dash is anyway, so to run another without solving the issue seems pointless unless I remove the controller.
  11. #17
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    The chassis is not earthed from factory. Nissan wiring (including earth circuits) is only just satisfactory for a standard vehicle. Once you start modifying it, adding extra electrical accessories and the wiring starts getting old this can cause all sorts of electrical problems. One "fix" is to add an earth strap between the body and chassis. This has even been recommended by Nissan. For something that cost so little to do I find it strange that you don't want to do it.
    Another known cause of fuel transfer electrical problems is the shut down timer. If the incorrect one has been installed this will bring on the sub tank light.
    The original fuel transfer switch is not an on/off switch it is a momentary switch. When the switch is pressed it sends a signal to the sub tank control unit. Then if the control unit sees all the correct information from the sensors in both fuel tanks it will switch on the fuel pump. I think the control unit also measures the power the fuel transfer pump is using and if this is out of spec or any of the other sensors are out of spec the control unit stops the fuel transfer and brings on the light.
    In your other post you said "I too wish to rewire this circuit". The easiest way to do this is to fit an on/off switch in the dash to switch a relay on and off that turns the fuel pump on and off. Then just remember to switch the pump off because the biggest killer of pumps is to run them dry.
  12. #18
    Patrol Freak gaddy's Avatar
    redlands
    The chassis is not earthed from factory. Nissan wiring (including earth circuits) is only just satisfactory for a standard vehicle. Once you start modifying it, adding extra electrical accessories and the wiring starts getting old this can cause all sorts of electrical problems. One "fix" is to add an earth strap between the body and chassis. This has even been recommended by Nissan. For something that cost so little to do I find it strange that you don't want to do .
    Hey rod is this just an extension of the body earth to the chassis , I'm not having any issues but it is s simple thing and I prefer prevention over a future falt . Sorry for the high jack
    Steve
  13. #19
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    Quote Originally Posted by gaddy View Post
    Steve
    That will work fine.
    Most people connect the earth from the body to the chassis near the fuel tanks.
    This is what Nissan recommended.
  14. The Following 2 Users Say Thank You to Yendor For This Useful Post:
    boots (13th January 2014), gaddy (14th January 2014)
  15. #20
    redlands
    Thanks , simple as
    Steve
