Results 1 to 10 of 15
Thread: Child seat anchor points
    Expert oddkid82's Avatar
    Apr 2013
    Hey guys I am just wondering what you have done with the anchor points in the back after your draws have gone in.
    I am in the process of designing my draw system and fridge slide but have no idea how to move the anchor point.
    Any ideas would be great
    Would you utilise the seatbelt Stalk bolt hole,
    Nah would need to see what you're doing
    I'd check under flooring as most floor plans are for Right and Left hand drive.
    You may find a ship load of captive nuts there
    Patrol Guru firm351's Avatar
    Jun 2013
    Mundijong, WA
    4 Post(s)
    We are getting a crab bar fitted to our GU. It's a child restraint anchor bar, in a GU it bolts to the sides of the cargo area where the two little square trim bits are. I need it because we want three anchor points for the middle row of seats. I like it because it brings the anchor points up to the level of the top of the seats so no straps going to the floor and the straps for the middle seat can't slip down the split in seat back.
    43 Post(s)
    I finished my draws just behind the anchor points, but continued top self right threw to the seats. Then drilled a large hole in the top self so the straps don't touch, and placed my cargo barrier just behind that.
    My draws are 900 long and top is 1100.. And I have a nice little storage area for things like water tank, toilet paper, and the non essentials.
    Here is my build.
    http://www.nissanpatrol.com.au/forum...d.php?p=361394
    Owner of
    Westy's Accessories
    Expert Blacklotusdog's Avatar
    My draws are double stack of 600mm high so just made them only 800mm long which sits flush with cargo barrier. This means they are just shorter then the anchor points so these are still available to use. Ill grab some photos of anchor points tonight but below is the draws. On second photo you can see where I made a cutout out for them but this probably wasn't needed in the end. It means there is a dead space here but I think I will use this for water storage or something.
    2012 GU8 Polar White Auto ST Patrol, Factory Bull bar, Scangauge 2, EGR blanked, Milford cargo barrier, Outback ideas recovery points, Micks retrofit HID 3 inch projectors with Osram bulbs and 55w ballasts, GME TXE3420, Sidewinder dual battery with monitor, Windcheetah 2.0m alloy rack, Suspension Stuff 2" Flexy lift with SS Monotubes, MT ATZ 4 ribs 265/75R16 on black Dynamic rims, Custom rear draws with fridge slide.
    Apr 2013
    If I had to move the points would they have to be engineered?
    43 Post(s)
    Quote Originally Posted by oddkid82 View Post
    Yep..
    Owner of
    Westy's Accessories
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    X 2 With Kallen, yes they would have 2 be certified / engineered for it to be legal
  11. #10
    Apr 2013
    Thanks guys have a few ideas now, will see what I can start on the weekend
