29th July 2013, 02:51 PM
They are pretty tough, I had one bolted to the roof of a trailer that got loose and went 150 mtrs down a mountain.
Still got it and still use it, but now as I have a different trailer I only set up if I need it. Just don't forget to chase the sun.
Not a fan of fixed solar as you need to park your 4x4 or trailer in the sun, but if only charging [topping up ] you'll be fine.
You have plenty of sun there so you be mad not to go solar IMO
80 watt panel put roughly 4.5 amps back in
100watt around 6 amps no real need to go bigger.
120watt folding if not mounting it.
For general usage an 80 watt will serve you well
29th July 2013 02:51 PM
29th July 2013, 04:07 PM
Thanks three dogs. Was thinking the bigger cell may compensate flat mount and not perfect angles etc
30th July 2013, 08:34 PM
Ok. Engel been running for 16.5 hours now. Was pre cooled. And is with NN120 battery.
