23rd July 2013, 10:03 PM
Auxiliary Tank
Hi. Just wondered if there is an easy way to check if aux tank is working. On start up the dash light comes on. Put when running if if I press the dash button for aux tank no light comes on.
Cheers.
Marty.
23rd July 2013 10:03 PM
23rd July 2013, 10:28 PM
Advanced
What sort of car you got mate????
2002 GU 3 Lt Patrol Wagon. On Board Air, ARB Front Air Locker, 2"Tough Dog Lift, Rear Air Bags, Tracklander Roof Rack, IPF HID Spotties, K&N Air Filter, Cargo Barrier, 3" Dominator Exhaust, Titan Drawers and much more.
23rd July 2013, 10:31 PM
Hardcore
If you are new to patrols the sub tank transfers to the mAIN tank once main tank is 3/4 full r less. So once your main tank is less than 3/4 press your sub tank button light will be on and watch sub go down and main go up
Whoever appeals to the law against his fellow man is either a fool or a coward.
Whoever cannot take care of themselves without that law is both.
For a wounded man shall say to his assailant,
'If I live, I will kill you. If I die, You are forgiven.'
Such is the rule of honour.
23rd July 2013, 10:33 PM
Thanks Macca. Does 12 hours count as new? 02 4.2TD ex Telstra.
Cheers. Marty.
The Following User Says Thank You to rafa For This Useful Post:
23rd July 2013, 10:36 PM
Hardcore
Aha yeah that's new. It ad me stumped too with the sub tank. If the sub tank light in your dash comes and stays on that means there is a fault with te sub tank. Also in diesel meds every time you start up it will transfer for 10 to 20 seconds so don't freak out if the sub goes dwn without touching the button
27th July 2013, 09:27 AM
Ok so with standard tanks at 110km/hr what a realistic range / consumption with the pod loaded. I've hit the button and the sub tank seems to be going down faster than the main is going up if that makes sense.
Marty.
27th July 2013, 09:51 AM
Legendary
rafa
Marty.
I am pretty sure that the main tank is larger than the sub tank, which makes it look like the gauge isn't moving far.
What size tanks do you have in your Telstra Ute?
Is your main tank full at the moment? ( That may explain why no fuel transfer, but the light should still work ... )
Cuppa has an ex-Telstra Ute, and he may be able to shed some light on what his has as standard.
Mic
27th July 2013, 09:58 AM
Not sure of tank size yet for main. But got 80 in sub when gauge was empty.
I pressed sub button when main at 3/4 tank now sub nearly half tank and main nearly half way between 3/4 and full. And have only done 210km since filling both. Light load in pod and 40 km city running around then on highway 100-110 km/hr. seems like a lot of fuel ImageUploadedByMotorculture1374881305.370176.jpg
Marty
27th July 2013, 10:06 AM
Legendary
Marty,
From standard main is 95 Litres, and sub is 80 Litres for the ute only.
Mic
27th July 2013, 10:08 AM
Legendary
Should use somewhere around the 14 - 15 Litres per hundred on the highway, so theoretically, you should see over 1200 K's from both your tanks .....
