Results 1 to 10 of 11
Thread: brakes problem nissan y61 model 1998 td42t
    Advanced roon's Avatar
    Jul 2012
    pakistan peshawar kpk
    Post brakes problem nissan y61 model 1998 td42t
    hi to all i have problem with my y61 brakes after 2 push its become hard and brake light in dash board turn on after some aceleration its become normal for only one push and at 2 push its become hard again i changed alternater but still that problem stands kindly help me and also abs not working completly dead[B[/B]
    Hardcore 04OFF's Avatar
    Brisbane,QLD
    12 Post(s)
    Have you checked the level in the brake fluid resivoir ?
    Aug 2010
    adelaide
    what about fuses have you checked them out
    thats the ones in the engin bay at side of battery
    OH LEATHER IS NICE
    Sep 2011
    adelaide
    18 Post(s)
    Check the vacuum pump and the check valve,you may have a vacuum leak or the pump is faulty also check all vacuum lines for soft areas or crimped hoses.Also the booster may have a vacuum leak.One check is while the engine is running apply the brakes by hand and have a listen under the dash by the brake pedal for a Constant hiss or air leak this noise will be related to the a leaking rear seal in the brake booster.
    Jul 2012
    yes brake fluid is full
    Jul 2012
    there are two batteries in my y61 and my 61 is RHD kindly massage me the no of fuse in fuse box
    Jul 2012
    Dear I think it will be help full to me thx for reply
    Jul 2012
    Is any body will post me the pic of y 61 engine and abs system piping
  10. #9
    Jul 2012
    My y61 is auto td42 turbo abs break
  11. #10
    Sep 2011
    adelaide
    18 Post(s)
    Roon mate
    If the ABS light is not flashing there is nothing wrong with the ABS.
    If the brake light comes on then goes off it can mean low fluid ,low vacumm , or the hand brake leaver is not fully returned
    If the ABS light is flashing get a professional to check the system as you need to read the codes which tell you where the problem is.
