Results 1 to 9 of 9
Thread: battery going flat
    south gippsland
    battery going flat
    hi i have a 01 st 4.2 cab chas ute if i leave it for 2 weeks with out starting the main battery goes flat have moved radios and acc to 2nd battery and still it happens have 2 new battery's in have a constant load of about 1 amp draw on the main battery have pulled all fuses one by one only changes .01 of an amp where to look or what is normal thanks for looking
    stuart
    Expert Steve4wdin's Avatar
    Feb 2012
    Western Sydney
    Yendor will be your man on this, but I would say check for bad earth on your starter motor.
    us poms are crap at cricket fracster's Avatar
    North West England.
    3 Post(s)
    I`m sure that I read ,on here, of a similar problem. I recall that the ALT was the problem.
    As above though, Yendor will have the answer and sure knows a helluva lot more about it than I do. But if you have pulled all the fuses and still get current draw, then I think YNOT is correct.
    It is now official, we are not quite so sh@t at cricket as we were! Rugby Union is a different matter.
    south gippsland
    hi
    checked alt not that will start pulling relays ?
    thanks
  6. #5
    When changing things to fault find, do one thing at a time ,cause if you do two or more things at once and you fix it,
    you'll never know what fixed it, M2cW
  7. #6
    Patrol Guru Drew's Avatar
    Western burbs of Melbourne
    Quote Originally Posted by YNOT View Post
    If you've pulled all the fuses and the current drain is still there it could be a faulty alternator, I've had it on one of my Patrols. Quick test is to disconnect the alternator and see if the current drawer remains..
    T.
    In dumb speak for me, I'm curious on how the alternator would be draining power ?
    2008 GU 3.0 CRD Auto - Life's too short to eat bad food.
  8. #7
    Internals are polling are [touching}From battery through the alternator to frome where ever
  9. The Following User Says Thank You to threedogs For This Useful Post:
    YNOT (20th July 2013)
  10. #8
    south gippsland
    hi thanks all
    found the problem last owner had wired the pyro gauge up too permanent 12volt power instead of switched have owned it for about 10 months and has bugged me the hole time but i love the ute
    thanks stuart
  11. #9
    Patrol God mudnut's Avatar
    SW Vic.
    80 Post(s)
    Quote Originally Posted by Drew View Post
    Also diodes can breakdown, allowing current to seep back through them.
