Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 40
Thread: Quick transfer case question
    Need to change my fluid too but it's a bit difficult to know what to use in my 94 gq...... Manual says to use the Nissan dmatic ATF, other folk have suggested using nothing other than 85-90w.......... Very very confusing indeed
    My folks went to the Google Play Store and all they got me was this lousy Motorculture App!!!!!!!
    Patrol God mudnut's Avatar
    SW Vic.
    80 Post(s)
    Is it making noises at all? The fluid in mine was almost black and ran out like water. I'm glad it takes under two litres so it isn't too expensive.
  4. #13
    No noises but there us a slight grumble that I can feel vibrate through the floor when moving off at slow speeds.......... Have changed diff oils several times but is still there. It's there no matter if I'm in 2h, 4h or 4l.
  5. #14
    SW Vic.
    80 Post(s)
    I think that grumble comes free with every older Patrol, doesn't it?
  6. #15
    I thought it was my missus at first but then she stopped talking
  7. The Following 3 Users Say Thank You to Clunk For This Useful Post:
    BigRAWesty (20th July 2013), mudnut (20th July 2013), Parksy (20th July 2013)
  8. #16
    Patrol Freak Parksy's Avatar
    Jan 2013
    Nowra NSW
    5 Post(s)
    Has anyone pulled apart a patrol transfer case? I tried doing some digging, and found an article of someone doing a transfer case rebuild, unfortunately it's not a patrol box. But internally, it has an oil pump with what looks like a pick up tube.
    http://www.euro4x4parts.com/en/mecha..._transfer.html
  9. The Following 2 Users Say Thank You to Parksy For This Useful Post:
    Clunk (20th July 2013), mudnut (20th July 2013)
  10. #17
    Some light reading for later me thinks lol
  11. #18
    Patrol Freak Rustyboner81's Avatar
    Perth
    Clunk give 'perth gearbox differential and clutch center' in belmont.
    They do a lot of 4by work and always happy to answer any questions i have for them.
    Sent from my GT-I9305T using Motorculture mobile app
    '92 (MIGHTY) GQ ST 3.0L Duel Petrol / LPG, 2" Pedders Suspension Lift on 33x12.5x15 BigHorns
    Lukey 2.5" Performance Exhaust with Extractors, snorkel
    Auto Lokka In The Front, Duel Batteries, Stiff Deep Dish Steering Wheel,
  12. #19
    Thanks Russ
  13. #20
    Advanced
    Jul 2013
    Namibia
    Quote Originally Posted by Parksy View Post
    Im bussy to work on mine. Currently mine is on the bench in several pieces. I took it out after I heard a tok,tok,tok sound. Thought it was a bearing at the rear end, so I started to work my way towards the front. Found one of two problems, not a bearing though, a broken tooth on a gear and the part worked its way in between other gears. This caused damage to the gears and needs to be replaced. The other problem is again slightly back. A gear that when spun by hand makes a crcrcrrrrr sound. Dont know how to deal with that one.
  14. The Following User Says Thank You to Bundu For This Useful Post:
    Parksy (23rd July 2013)
