5th September 2013, 03:27 PM
#21
mine is the direct injected ZD30, before dawes and needle were fitted boost would do the same symptoms as yours. once fitted sits on 11 psi @ 100 clicks and stays there. don't know about common rail but fit dawes and needle as mudski suggested. [no more problems]
3lt GU 111 Wagon 2 inch lift,3in Taipan exhaust, cross country intercooler,catch can,EGR blocked, dawes and needle valve,Pyro/boost gauge ARB lockers,steinbaurer chip, long range tank, s/s water tank, draws, warn winch, and other stuff.
5th September 2013 03:27 PM
5th September 2013, 04:17 PM
#22
And block the EGR after the valves are fitted...
5th September 2013, 06:25 PM
#23
more info here
more info here:
http://www.nissanpatrol.com.au/forum...9727-egr-block
CRDs do get the engine code randomly (depending on temp conditions?), just clear it with an ultragauge/scangauge. Or drill a hole but that kinda defeats the purpose.
Zorst and EGR block will raise ya boost
Chip, Dawes and Needle will fix it all.
Patrol GU8, Manual, snorkel, steel bull bar, Simpson Ed
7th September 2013, 03:30 PM
#24
Yeah the Nissan service manager suggest EGR block & workshop foreman suggested Dawes valve! I asked what about warranty and the answer was it mite effect it!
2012 GU8 ST manual.. Not so stock standard anymore
7th September 2013, 03:33 PM
#25
Schanmala I'm running and Ultra gauge (great bit of gear) and the reason I found the issue. Will hopefully finish off wiring up the Autron gauges tomorrow & fingers crossed the Dawes valve turns up by Friday cause only 10 days and it's up the Cape for 5 1/2 weeks
