19th July 2013, 05:22 PM
#11
Is your IC oily, at all.
Mine sits @ 10PSI doing 100 kph constantly
19th July 2013 05:22 PM
27th July 2013, 10:23 PM
#12
Threedogs - I checked the intercooler had a small amount of oil in it.
I now have the new intercooler and catch can installed as well as the 3" exhaust and it's still doing it but climbing up to 20 psi now??? One thing have noticed on my ultra gauge is when the engine load is around 56% - 58% is when the boost wants to heads north?? The chip goes in Tuesday so I'll see if that changes any thing otherwise back to Nissan I go!!!
2012 GU8 ST manual.. Not so stock standard anymore
31st July 2013, 08:26 PM
#13
If you block your EGR, your boost level may rise even more. Install a Dawes valve, at the least, and your problems will go for ever. Add a needle valve into the mix and you will have the power to make your CRD go even better.
31st July 2013, 09:09 PM
#14
I thought the crd needed a 10mm hole in it Or it will throw error codes or limp mode.
31st July 2013, 10:40 PM
#15
I haven't come across one yet. Sold around 100 plates in the last five or so months and no reports yet. But having said that. There is a first time for everything. Being a CRD I am surprised really.
1st August 2013, 07:41 AM
#16
Crd sometimes throw egr flow error code. Easily cleared with scangauge or similar and definitely does not go into limp mode.
2012 GU8 Polar White Auto ST Patrol, Factory Bull bar, Scangauge 2, EGR blanked, Milford cargo barrier, Outback ideas recovery points, Micks retrofit HID 3 inch projectors with Osram bulbs and 55w ballasts, GME TXE3420, Sidewinder dual battery with monitor, Windcheetah 2.0m alloy rack, Suspension Stuff 2" Flexy lift with SS Monotubes, MT ATZ 4 ribs 265/75R16 on black Dynamic rims, Custom rear draws with fridge slide.
The Following User Says Thank You to Blacklotusdog For This Useful Post:
1st August 2013, 07:53 AM
#17
The ECU on the CRD is more tolerant of higher boost levels,
This Chip you mention is it after market and Nissan are fitting it,??
With the IC being oily it may mean its leaking, so my point being how can it hold boost.?
12th August 2013, 07:11 AM
#18
Three dogs its a tunit chip and not installed by nissan, but the chip has made no difference as the issue is still there. I have booked it back into Nissan and I reckon its due to engine load certain speeds as when I sit on 120 boost sits happy at 12psi, drop down in speed and either using accelerator or cruise control boost will climb up to 20psi at a certain % of engine load??
Sent from my AMID-9743G using Tapatalk 2
12th August 2013, 08:17 AM
#19
Have you blocked the correct end of the EGR pipe ???
Disconnect your battery for 1/2 an hour
1st September 2013, 09:50 PM
#20
Disconnected the battery for hours and still the same. Took it back to Nissan again! Still no answer there still waiting to hear back from Nissan tech. In the meantime I've brought a Dawes valve at least I know that sort the issue once an for all!
