Results 1 to 10 of 10
Thread: GU TD2.8 - Putting an additive into gearbox oil
    Beginner Forbes4x4's Avatar
    Brisbane, Queensland
    Silly question regarding my GU TD2.8.. I'm wanting put an additive into my gearbox oil to quieten a little rattle it make in neutral and to generally make it a little smoother. Problem is that I can't find the hole! The gearbox filler hole that is
    Can anyone point me in the right direction so I can put this additive in?
    North brissy
    Possible on the drivers side about half way up the box, it might have a 1/2" square drive in it.
  4. The Following User Says Thank You to nissannewby For This Useful Post:
    Forbes4x4 (18th July 2013)
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    Don't know about GU's or manual gearboxes but on the GQ Auto box there is no filler hole, you have to pump it down the small dipstick hole!!! Maybe yours is the same
    Edit: I have also renamed your thread title as you might get more response
  6. The Following User Says Thank You to NissanGQ4.2 For This Useful Post:
  7. #4
    Thanks for the advice guys. I'm having a mechanic mate of mine look at it tomorrow - was a bit embarrassed to ask but at least it's better to do that then guess, put in in the wrong hole and really screw something up! Will let you know how I go!
  8. #5
    461 Post(s)
    Does this rattle in neutral go away once you put your foot on the clutch? Is so thats the clutch release bearing carrier rattling on the nose cone.
    Mine did this noise, then I replaced the clutch, cleaned up the nose cone, greased up the carrier, and it went away. Six months later its back The grease has obviously gorn...
  9. The Following 2 Users Say Thank You to mudski For This Useful Post:
    Forbes4x4 (20th July 2013), tonyhoughton (9th August 2013)
  10. #6
    Expert tassie wombat's Avatar
    orielton,tasmania
    My old gq box was the same,pretty sure its the input shaft bearing in the gearbox,I tried some additive from wynns,and didn't make an ounce of differance !
  11. The Following User Says Thank You to tassie wombat For This Useful Post:
  12. #7
    I just had a new heavy duty clutch and solid fly wheel put in (the old original ones died; couldn't even move it a cm)! The rattle stops as soon as I put in gear and start moving. I'd say its the input shaft bearing.. The additive I got was Nulon and am hopefully putting it in tomorrow. I'll post again if it works! Was about $23/tube from supercheap.
  13. #8
    Advanced mortn's Avatar
    Aug 2013
    Bergen, Norway
    Quote Originally Posted by Forbes4x4 View Post
    Did it?? Same problem here!
    1992 Patrol GR 2,8TD
    4 inch body lift, 35'' procomp xterrain, Newly restored exterior. Thrashed interior.
  14. #9
    Put half a bottle of moreys oil stabilizer in.. rattle masked..
  15. #10
    Advanced tonyhoughton's Avatar
    South Lake, Perth
    I just had a gearbox rebuild... New HD clutch and fly wheel milled... And I also have the rattle when in neutral with the clutch engaged. Drop the clutch and it's gone...
    As there's 3 of us hearing this, is this to be expected? Is it doing damage? Should I take it back?
    Sent from my GT-I9505 using Tapatalk 2
    2006 4.2, UFI 18G, 3" Mandrel, Cross Country IC, 470NM, 183HP @ Rear Wheels
    2" Lift, Twin Air Lockers, 43% Reduction Gears (Saving up for Portal Axles)
    Plus many many more mods!
