Results 31 to 36 of 36
Thread: Ultra gauge obd2
  1. #31
    Thanks did some probing and came up with the fact the 2004 Di zd30 has a 14 pin Grey OBD2 pin and I can get ECUtalk for $97
    does that sound like the right price, all you get is plug in lead 1.5 long to a USB, if that's right I'll fit a 10" screen in the dummy glovebox lid.
    Have also sent a message to Scangauge on Ebay.
    I'll get an answer one way or another
    Mar 2013
    Thanks for the info guys, ordered Ecutalk last night to use on my 2002 ZD30 Patrol which has the OBII plug, hopefully get it this week.
  4. #33
    Expert patrol2.8's Avatar
    Nov 2011
    vic
    I run the ecutalk but mine is an obd1 plug Peter who sells the ecutalks is the most helpful bloke ive had mine for over 12 months now and any questions I have are answered quickly his back up service is second to none as for the usb port there is a small program you download from the website which allows you to run more gauges on your laptop depending on the year of your vehicle etc also allows you to check and clear any fault codes that the car throws up just for the record I do not know Peter personaly
    Theres only one thing tougher than my truck............. YES DEAR GOING TO DO THE LAWNS NOW
    WARNING: Towballs used for recoveries,can and do kill people and damage property
  5. #34
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    John can you post me up a link to what you are getting for $97
    If you are only getting a lead it will be no good to you
  6. #35
    Sydney
    I have been running the Ultragauge on my GU7 for the last few years. It reads all available parameters but does not display fault codes.
    If the engine check light comes on you can clear the fault but you can't read the fault code. It can't detect fault codes.
    I like the screen as it is easy to read and configure and also has the option of setting alarms.
    But due to the fact that I can't read the fault code I have now fitted a scangauge 2.
    The display is lacking but at least I know what is triggering the eng check light.
  7. #36
    May 2016
    Brisbane
    I have recently purchased an ultra gauge. They now show fault codes.
    They can also be cleared.
    Nice gauge, easy to read and easy to program and calibrate.
