22nd January 2014, 09:45 PM
#41
MudRunnerTD
Not just because your removing the sway bar. have you still go the rear sway bar in? Did you fit the 4" lift? did you make any allowances for adjusting the bump stops then? Drop out cones will really depend on the open length of your rear shocks.
I didn't fit the lift. It's a tough dog springs and panhard rods with west coast suspension shocks. Extended links and all that there standard bump stops
22nd January 2014 09:45 PM
22nd September 2014, 10:16 PM
#42
Does any one have any experience with off set bearings for swivel hubs as opposed to drop boxes saw some advertised they look cosy effective if they work. Cheers kev
22nd September 2014, 10:22 PM
#43
Moderator
bigkevlittletruck
They do two completely different things. In fact I have both fitted to my GUIV with a 3" lift.
The offset king pin bearing is fitted to the left side upper king pin bearing to add camber to accommodate the camber on Australian roads and can be added to vehicles suffering from front end shimmy.
The drop boxes specifically add Caster correction and are very effective for a lift of 3" or more.
Check out my Toy -->
Rogue Dung Beetle
23rd September 2014, 09:56 PM
#44
Thanks for that mudrunner that's cleared that for me
